Introduction to Smart Client themes
The XProtect Smart Client supports two color themes, "Light" and "Dark". The user toggles between these themes by selecting the Toggle theme button located in the upper-right corner of the Smart Client application window.
The MIP Environment for the Smart Client makes it possible to integrate and use these themes. Both WPF and WinForms user controls are supported.
See also Recommended user controls
WPF user controls
Implementation guidelines
User controls that are derived from System.Windows.Controls.Control are
automatically themed by the Smart Client.
To disable ViewItem toolbar
If a ViewItemWpfUserControl has user controls such as scroll or buttons at
the bottom, you can disable this toolbar by overriding the ShowToolBar
property:
public override bool ShowToolbar
get { return false; }
If ShowToolbar returns true, the toolbar scrolls up from the
bottom when the mouse hovers over your ViewItemWpfUserControl.
To override theming
For most WPF UserControls, you can override Smart Client theming by
setting the Style of the control.
For example, in the Smart Client Theme sample code, the style properties applied in the XAML file for TextBlock won't be affected by Smart Client theme changes:
<Grid>
<TextBlock Text="This WPF User Control is not auto themed." TextWrapping="Wrap" Padding="5" TextAlignment="Center">
<TextBlock.Style>
<Style>
<Setter Property="TextBlock.Background" Value="#FFE5E5E5"/>
<Setter Property="TextBlock.Foreground" Value="Black"/>
<Setter Property="TextBlock.FontSize" Value="25"/>
</Style>
</TextBlock.Style>
</TextBlock>
</Grid>
The old WinForms classes are still available, but it is recommended that all new development uses WPF controls.
By default, the MIP Environment automatically themes the parts of the MIP plug-in that are normally simple to handle and look well.
The following Smart Client UserControls are automatically themed by the Smart Client:
SidePanelUserControlPropertiesUserControlOptionsDialogUserControlPlaybackUserControlUserControlreturned bySettingsPanelPlugin
We recommend that the development focus for applying and supporting different themes is
done on the ViewItemUserControl.
For a ViewItemUserControl, the recommended implementation consists of
three areas:
- Ensure that the header line has the correct background and foreground based on the selection and theme.
- Have the main part of the
ViewItemplaced in a single panel, and use theClientControl.Instance.RegisterUIControlForAutoTheming(myPanel)for letting the XProtect Smart Client theme all user controls within the panel. - Decide if the toolbar at the bottom should be enabled or not.
If you implement your own buttons or your own use of icons, you may consider to have
multiple sets of icons. You may also consider replacing the buttons and icons when you
receive the ThemeChangedIndication.
If you have designed your ViewItem to match your company colors or you
have your own color scheme, you do not have to apply any theme properties on your
ViewItem.
If a ViewItemUserControl has user controls such as scroll or buttons at
property:
bottom when the mouse hovers over your ViewItemUserControl.
Code Snippets
These snippets can be used to apply theme support for a ViewItemUserControl.
Create method for updating the colors of the child controls (in this case panelHeader) according to theme and selection state:
private void ApplySelectionColors()
if (Selected)
panelHeader.BackColor = ClientControl.Instance.Theme.ViewItemSelectedHeaderColor;
panelHeader.ForeColor = ClientControl.Instance.Theme.ViewItemSelectedHeaderTextColor;
else
panelHeader.BackColor = ClientControl.Instance.Theme.ViewItemHeaderColor;
panelHeader.ForeColor = ClientControl.Instance.Theme.ViewItemHeaderTextColor;
Define object for message reception:
private object _themeChangedReceiver;
Register a receiver for any changes in the current theme, during the
Init() call :
_themeChangedReceiver = EnvironmentManager.Instance.RegisterReceiver(
new MessageReceiver(ThemeChangedIndicationHandler),
new MessageIdFilter(MessageId.SmartClient.ThemeChangedIndication));
Unregister during the Close() call:
EnvironmentManager.Instance.UnRegisterReceiver(_themeChangedReceiver);
Implement a handler for the theme change. Invoke the ApplySelectionColors method:
private object ThemeChangedIndicationHandler(
VideoOS.Platform.Messaging.Message message, FQID destination, FQID source)
ApplySelectionColors();
return null;
In the class construction, register the panel that contains all user controls except the header and set the header colors as not selected:
ClientControl.Instance.RegisterUIControlForAutoTheming(panelMain);
Override the Selected property to invoke the ApplySelectionColors method:
/// <summary>
/// Ensure we theme the header
/// </summary>
public override bool Selected
get { return base.Selected; }
set {
base.Selected = value;
To suppress theming
When a WinForms UserControl for some reason should not be themed,
the following assignment to the UserControl's Tag property
will prevent this UserControl and all inner controls from being themed:
this.Tag = "DoNotThemeMe";
