Base class for all primary tab controls. More...
Static Public Attributes | |
static readonly DependencyProperty | ItemActionsPropertyNameProperty |
Identifies the ItemActionsPropertyName dependency property. | |
static readonly DependencyProperty | ItemAlertPropertyNameProperty |
Identifies the ItemAlertPropertyName dependency property. | |
static readonly DependencyProperty | ItemIconSourcePropertyNameProperty |
Identifies the ItemIconSourcePropertyName dependency property. | |
static readonly DependencyProperty | ContentTemplateProperty |
Identifies the ContentTemplate dependency property. | |
static readonly DependencyProperty | IsContentBorderVisibleProperty |
Identifies the IsContentBorderVisible dependency property. | |
static readonly DependencyProperty | IsContentVisibleProperty |
Identifies the IsContentVisible dependency property. | |
static readonly DependencyProperty | ItemAutomationIdPropertyNameProperty |
Identifies the ItemAutomationIdPropertyName dependency property. | |
static readonly DependencyProperty | ItemContentTemplatePropertyNameProperty |
Identifies the ItemContentTemplatePropertyName dependency property. | |
static readonly DependencyProperty | ItemDataPropertyNameProperty |
Identifies the ItemDataPropertyName dependency property. | |
static readonly RoutedEvent | ItemDragInitiatedEvent |
Identifies the ItemDragInitiated routed event. | |
static readonly DependencyProperty | ItemIsDraggablePropertyNameProperty |
Identifies the ItemIsDraggablePropertyName dependency property. | |
static readonly DependencyProperty | ItemIsEnabledPropertyNameProperty |
Identifies the ItemIsEnabledPropertyName dependency property. | |
static readonly DependencyProperty | ItemSeparatorPlacementProperty |
Identifies the ItemSeparatorPlacement dependency property. | |
static readonly DependencyProperty | ItemsSourceProperty |
Identifies the ItemsSource dependency property. | |
static readonly DependencyProperty | ItemTextPropertyNameProperty |
Identifies the ItemTextPropertyName dependency property. | |
static readonly DependencyProperty | ItemToolTipPropertyNameProperty |
Identifies the ItemToolTipPropertyName dependency property. | |
static readonly RoutedEvent | SelectedItemChangedEvent |
Identifies the SelectedItemChanged routed event. | |
static readonly DependencyProperty | SelectedItemProperty |
Identifies the SelectedItem dependency property. | |
Protected Member Functions | |
override AutomationPeer | OnCreateAutomationPeer () |
Properties | |
string | ItemActionsPropertyName [get, set] |
Gets or sets the name of the property on the items (from VideoOSTabControlBase.ItemsSource) which contains the actions associated with the tab item. NOTE: This property is not relevant if the items in VideoOSTabControlBase.ItemsSource are VideoOSTabControlPrimaryItem instances. The property identified by this name must be of type ICollection<VideoOSActionBase>. | |
string | ItemAlertPropertyName [get, set] |
Gets or sets the name of the property on the items (from VideoOSTabControlBase.ItemsSource) which contains the alert associated with the tab item. NOTE: This property is not relevant if the items in VideoOSTabControlBase.ItemsSource are VideoOSTabControlPrimaryItem instances. The property identified by this name must be of type VideoOSAlert. | |
string | ItemIconSourcePropertyName [get, set] |
Gets or sets the name of the property on the items (from VideoOSTabControlBase.ItemsSource) which contains the VideoOSIconSourceBase representing the icon of the item. If not set, the item will not show an icon. NOTE: This property is not relevant if the items in VideoOSTabControlBase.ItemsSource are VideoOSTabControlPrimaryItem instances. The property identified by this name must be of type inheriting from VideoOSIconSourceBase. See VideoOSIconSourceBase for more information. | |
DataTemplate | ContentTemplate [get, set] |
Gets or sets a data template used to visualize the tabs content the tab control. NOTE: If the items in ItemsSource are derived from VideoOSTabControlItemBase, this can be overruled by the VideoOSTabControlItemBase.ContentTemplate property. NOTE: If the items in ItemsSource are not derived from VideoOSTabControlItemBase, this can be overruled by a DataTemplate returned by an item property identified by the name in ItemDataPropertyName. NOTE: If no content data template is set "anywhere" then the tabs content is visualized using a default visualization. | |
bool | IsContentBorderVisible [get, set] |
Gets or sets a value indicating if the tab control content border is visible or not. | |
bool | IsContentVisible [get, set] |
Gets or sets a value indicating if the tab control content is visible or not. If false only the tab headers will be displayed. Note that if set to false it will in most cases make sense that IsContentBorderVisible is also set to false. | |
string | ItemAutomationIdPropertyName [get, set] |
Gets or sets the name of the property on the items (from ItemsSource) which holds the desired System.Windows.Automation.AutomationProperties.AutomationIdProperty that should be applied on the created System.Windows.FrameworkElement. NOTE: This property is not relevant if the items in ItemsSource are derived from VideoOSTabControlItemBase. The property identified by this name must be of type string. | |
string | ItemContentTemplatePropertyName [get, set] |
Gets or sets the name of the property on the items (from ItemsSource) which contains a DataTemplate that will be used for the visualization of the tab item content. If not set, a built-in template will be used. NOTE: This property is not relevant if the items in ItemsSource are derived from VideoOSTabControlItemBase. The property identified by this name must be of type DataTemplate. | |
string | ItemDataPropertyName [get, set] |
Gets or sets the name of the property on the items (from ItemsSource) which contains the data associated with the tab item. If set to null (default) then the item it selves will be used. NOTE: This property is not relevant if the items in ItemsSource are derived from VideoOSTabControlItemBase. The property type can be any type and is passed transparently into the FrameworkElement.DataContext of the UI representing the tab item content. | |
string | ItemIsDraggablePropertyName [get, set] |
Gets or sets the name of the property on the items (from ItemsSource) which indicates if the item is draggable or not. If not set, the item in not draggable. NOTE: This property is not relevant if the items in ItemsSource are derived from VideoOSTabControlItemBase. The property identified by this name must be of type bool. | |
string | ItemIsEnabledPropertyName [get, set] |
Gets or sets the name of the property on the items (from ItemsSource) which indicates if the item is enabled or not. If not set, the item will be enabled by default. NOTE: This property is not relevant if the items in ItemsSource are derived from VideoOSTabControlItemBase. The property identified by this name must be of type bool. | |
ItemSeparatorPlacements | ItemSeparatorPlacement [get, set] |
Gets or sets a value indicating the placement of the item tab header separators. Default value is ItemSeparatorPlacements.Between. | |
ICollection | ItemsSource [get, set] |
Gets or sets a collection of items where each item will be represented as a tab in the tab control. The current items can by changed by modifying the content of this collection. | |
string | ItemTextPropertyName [get, set] |
Gets or sets the name of the property on the items (from ItemsSource) which contains the text to be displayed in the tab control header for the item. NOTE: This property is not relevant if the items in ItemsSource are derived from VideoOSTabControlItemBase. The property identified by this name must be of type string. | |
string | ItemToolTipPropertyName [get, set] |
Gets or sets the name of the property on the items (from ItemsSource) which contains the tab tool tip text to be displayed for the item. NOTE: This property is not relevant if the items in ItemsSource are derived from VideoOSTabControlItemBase. The property identified by this name must be of type string. | |
object | SelectedItem [get, set] |
Gets or sets the item representing the tab that is currently selected in the tab control. | |
Additional Inherited Members | |
enum | ItemSeparatorPlacements { None = 0 , Between = 1 << 1 , BeforeFirst = 1 << 2 , AfterLast = 1 << 3 , All = Between | BeforeFirst | AfterLast } |
Specifies the item tab header separator placement flags. More... | |
RoutedEventHandler | ItemDragInitiated [add, remove] |
Signals that an item header drag operation is being initiated by the user using the mouse. Listen for this event and use the DragDrop.DoDragDrop method to start the drag-and-drop operation supported by WPF. The RoutedEventArgs available in the event handler is of the type ItemDragInitiatedEventArgs containing information about associated item. | |
RoutedEventHandler | SelectedItemChanged [add, remove] |
Signals that the selected item (node) in the tree has changed. | |
inlineprotected |
static |
static |
static |
getset |
getset |
getset |
