A single-entry point for performing searches across the VMS system. The search manager will expose all available searches supplied by loaded search agent plugins. A search can be started across multiple search agents and run simultaneously by the search manager.
More...
Public Member Functions | |
bool | CancelSearch (IEnumerable< SearchDefinition > definitions) |
Attempt to cancel the currently running search based on there search criteria. This will only signal the search agent plugin to cancel a search and then return. After calling this, no more results from the cancel search will be returned. | |
SearchDefinition | CreateSearchDefinition (SearchFilterCategory searchFilterCategory, SearchScope searchScope) |
Creates a new search definition based on a search category. | |
void | DestroySearchDefinition (SearchDefinition searchDefinition) |
Destroys the provided search definition. | |
void | Dispose () |
Dispose the SearchManager, and then signal all running searches to cancel. | |
SearchManager () | |
Creates a new SearchManager for performing searches across the VMS system. | |
SearchManager (IEnumerable< SearchAgentPlugin > searchAgentPlugins) | |
Creates a new SearchManager for performing searches across the VMS system using the provided search agent plugins. | |
void | StartSearch (SearchDefinition definition, DateTime from, DateTime to, IEnumerable< Item > items) |
Starts a new search based on the given search criteria. Only one search can be started at a time. If a new search is started the previous search is canceled, and any subsequent result is ignored. This is equivalent to calling CancelSearch first. | |
void | StartSearch (SearchDefinition definition, DateTime from, DateTime to, IEnumerable< Item > items, Guid sessionId) |
void | StartSearch (SearchDefinition definition, DateTime from, DateTime to, IEnumerable< Item > items, SearchSortOrder sortOrder) |
void | StartSearch (SearchDefinition definition, DateTime from, DateTime to, IEnumerable< Item > items, SearchSortOrder sortOrder, Guid sessionId) |
Protected Member Functions | |
virtual void | Dispose (bool disposing) |
Override to handle disposing objects in inherited classes. | |
virtual void | FireErrorOccurred (SearchError searchError, SearchDefinition searchDefinition, Guid sessionId) |
Fire ErrorOccurred events. | |
virtual void | FirePartialResultReady (IEnumerable< SearchResultData > searchResults, SearchDefinition searchDefinition, Guid sessionId) |
Fire SearchResultReady events. | |
virtual void | FireSearchDone (SearchDefinition searchDefinition, Guid sessionId) |
Fire SearchDone events. | |
Properties | |
ReadOnlyCollection< SearchFilterCategory > | SearchFilterCategories [get] |
Returns all search filter categories from all the loaded search agent plugins. | |
Events | |
EventHandler< SearchErrorEventArgs > | ErrorOccurred |
An event used to inform the caller about run-time error. | |
EventHandler< SearchDoneEventArgs > | SearchDone |
An event used to inform the caller that a started search has completed. | |
EventHandler< SearchResultReadyEventArgs > | SearchResultReady |
An event used to inform that a set of results is ready. | |
inline |
inline |
searchAgentPlugins | Search agent plugins to add to the search manager. |
inline |
definitions | A list of search definitions to cancel. |
inline |
searchFilterCategory | The category to base the definition on. |
searchScope | The search scope associated with the definition. |
inline |
searchDefinition | The search definition to destroy. |
inline |
inlineprotectedvirtual |
disposing | Indicate if the method is called from Dispose() or the finalizer. |
searchError | The search error that occurred. |
searchDefinition | The Search.SearchDefinition which initiated the search. |
sessionId | A unique session id identifing the search where the exception originated from. |
searchResults | The enumerable representing a chunk of SearchResultDatas ready to be offloaded. |
sessionId | A unique session id identifying the search where the result originated from. |
searchDefinition | The search definition that has completed. |
sessionId | The sessionId firing the search done event. |
inline |
definition | A search definition on which to start a search. |
from | The start of the time span in which to search. |
to | The end of the time span in which to search. |
items | The items (i.e. cameras) to include in the search. |
inline |
sessionId | Session ID |
inline |
sortOrder | The order in which the results should be delivered. |
inline |
get |
EventHandler<SearchErrorEventArgs> VideoOS.Platform.Search.SearchManager.ErrorOccurred |
EventHandler<SearchDoneEventArgs> VideoOS.Platform.Search.SearchManager.SearchDone |
EventHandler<SearchResultReadyEventArgs> VideoOS.Platform.Search.SearchManager.SearchResultReady |
