Contains fields relevant for a ConfiguratonItem with category = "ChildItem". More...
Public Member Functions | |
string | GetProperty (string key) |
Return a property value as string, if key is not found the return value will be null. | |
ICollection< string > | GetPropertyKeys () |
Get a collection of all available property keys. | |
List< ValueTypeInfo > | GetValueTypeInfoList (string propertyKey) |
Get defined ValueTypeInfo for a given property. If no ValueTypeInfo is available, an empty list is returned. | |
void | SetProperty (string key, string content) |
Sets the value of a property (all is string format here) | |
override string | ToString () |
Display the 'DisplayName' is the default ToString() | |
Properties | |
string | Description [get, set] |
Description. | |
virtual string | DisplayName [get] |
Name of this ConfigurationItem in user readable format. Usually the same as property with key = "Name". | |
string | ItemCategory [get] |
Return the item category for this item. This can be used to understand how multiple items are fetched and saved together. Only ItemCategory == 'Item' can be saved. | |
string | Name [get, set] |
Name. | |
string | ParentItemPath [get] |
Get hold of the next real parent path, e.g. skip any 'Folder' type parent. | |
string | ParentPath [get] |
The path for the parent of this ConfigurationItem. | |
string | Path [get] |
The identification of this item. | |
ServerId | ServerId [get, set] |
Contains the ServerId of the Management Server holding this item. | |
inline |
key |
inline |
inline |
propertyKey |
inline |
key | |
content |
inline |
getset |
Description.
get |
get |
getset |
Name.
get |
get |
get |
