VideoControl is an easy to use UI component for showing a camera view in MIP plugin UI. The control creates a view of cameras having the same functionality as a normal view in the Smart Client. This means that features like live mode, playback mode, playback synchronization, camera selection, camera maximization, PTZ, independent playback, camera toolbar, timeline etc. is handled automatically by the control.
More...
virtual void | ClearOverlay (int cameraIndex, int id) |
| Clear a specific overlay placed earlier. The id used during the SetOverlay() call is used in this method for clearing that overlay again.
void | Close () |
| Closes the VideoControl. Call this method when it is removed from the UI.
virtual Size | GetPaintSize (int cameraIndex) |
| Get the paint size of the image viewer control at the specified index. Use this for generating overlay of the correct dimensions.
virtual void | SetOverlay (int cameraIndex, Bitmap bitmap, int id, bool keepAspectRatio, bool scaleWithDigitalZoom, bool scaleOverlay, double scaleFactor, DockStyle verticalDock, DockStyle horizontalDock, double absolutePosX, double absolutePosY) |
| Set an overlay on top of the video being displayed.
virtual void | SetTimelineSelection (DateTime from, DateTime to) |
| Enables time selection mode and applies the provided selection times.
virtual Guid | ShapesOverlayAdd (int cameraIndex, List< Shape > overlayShapes, ShapesOverlayRenderParameters renderParameters) |
| Set an overlay on top of the video being displayed. The returned id is used for updating and removing the overlay. If the specified cameraIndex is invalid, Guid.Empty will be retuned.
virtual void | ShapesOverlayRemove (int cameraIndex, Guid id) |
| Clear a specific overlay placed earlier. The id used during the ShapesOverlayAdd() call is used in this method for clearing that overlay again.
virtual bool | ShapesOverlayUpdate (int cameraIndex, Guid id, List< Shape > overlayShapes, ShapesOverlayRenderParameters renderParameters) |
| Update a specific overlay placed earlier. The id used during the ShapesOverlayAdd() call is used in this method for updating that overlay.
bool | AutoSelectFirstCamera [get, set] |
| Gets or sets whether the first camera should be auto selected by the control when the camera view is loaded.
List< FQID > | Cameras [get, set] |
| Gets or sets the list of cameras shown by the control. When set a layout matching the numbers of cameras will automatically be created.
bool | Live [get, set] |
| Gets or sets whether the control is in live mode or not. If set to false then the control is in playback mode.
DateTime | PlaybackTime [get, set] |
| Gets or sets the current playback time.
FQID | SelectedCamera [get, set] |
| Gets or sets the current selected camera.
virtual TimelineMode | TimelineMode [get, set] |
| Gets or sets the timeline mode shown by the control.
virtual TimeSpan | TimelineSpan [get, set] |
| Gets or sets the timeline span.
Guid | WindowId [get, protected set] |
| Gets the window ID assigned to this VideoControl (not to be confused with the ID of the window containing the control).
virtual EventHandler | PlaybackTimeChanged |
| Event that is fired when the playback time changed. The new playback time can be accessed through the PlaybackTime property.
EventHandler | SelectedCameraChanged |
| Event that is fired when the selected camera is changed. The new selected camera can be accessed through the SelectedCamera property.
◆ VideoControl()
VideoOS.Platform.Client.VideoControl.VideoControl |
inlineprotected |
◆ ClearOverlay()
virtual void VideoOS.Platform.Client.VideoControl.ClearOverlay |
int | cameraIndex, |
int | id ) |
inlinevirtual |
- Parameters
cameraIndex | The index of the camera in Cameras that the overlay should be applied on |
id | |
◆ Close()
void VideoOS.Platform.Client.VideoControl.Close |
abstract |
◆ GetPaintSize()
virtual Size VideoOS.Platform.Client.VideoControl.GetPaintSize |
int | cameraIndex | ) |
inlinevirtual |
- Parameters
cameraIndex | The index of the camera in Cameras |
- Returns
◆ OnPlaybackTimeChanged()
virtual void VideoOS.Platform.Client.VideoControl.OnPlaybackTimeChanged |
inlineprotectedvirtual |
Internally used to call on event PlaybackTimeChanged.
◆ SetOverlay()
virtual void VideoOS.Platform.Client.VideoControl.SetOverlay |
Bitmap | bitmap, |
int | id, |
bool | keepAspectRatio, |
bool | scaleWithDigitalZoom, |
bool | scaleOverlay, |
double | scaleFactor, |
DockStyle | verticalDock, |
DockStyle | horizontalDock, |
double | absolutePosX, |
double | absolutePosY ) |
inlinevirtual |
- Parameters
bitmap | |
id | |
keepAspectRatio | |
scaleWithDigitalZoom | |
scaleOverlay | |
scaleFactor | |
verticalDock | |
horizontalDock | |
absolutePosX | |
absolutePosY | |
◆ SetTimelineSelection()
virtual void VideoOS.Platform.Client.VideoControl.SetTimelineSelection |
DateTime | from, |
DateTime | to ) |
inlinevirtual |
- Parameters
from | The beginning of the selection. |
to | The end of the selection. |
◆ ShapesOverlayAdd()
virtual Guid VideoOS.Platform.Client.VideoControl.ShapesOverlayAdd |
List< Shape > | overlayShapes, |
ShapesOverlayRenderParameters | renderParameters ) |
inlinevirtual |
- Parameters
overlayShapes | |
renderParameters | |
- Returns
◆ ShapesOverlayRemove()
virtual void VideoOS.Platform.Client.VideoControl.ShapesOverlayRemove |
Guid | id ) |
inlinevirtual |
- Parameters
id | Id of the overlay to remove |
◆ ShapesOverlayUpdate()
virtual bool VideoOS.Platform.Client.VideoControl.ShapesOverlayUpdate |
Guid | id, |
inlinevirtual |
- Parameters
id | Id of the overlay to update |
overlayShapes | |
- Returns
◆ AutoSelectFirstCamera
bool VideoOS.Platform.Client.VideoControl.AutoSelectFirstCamera |
getsetabstract |
◆ Cameras
List<FQID> VideoOS.Platform.Client.VideoControl.Cameras |
getsetabstract |
◆ Live
bool VideoOS.Platform.Client.VideoControl.Live |
getsetabstract |
◆ PlaybackTime
DateTime VideoOS.Platform.Client.VideoControl.PlaybackTime |
getsetabstract |
◆ SelectedCamera
FQID VideoOS.Platform.Client.VideoControl.SelectedCamera |
getsetabstract |
◆ TimelineMode
virtual TimelineMode VideoOS.Platform.Client.VideoControl.TimelineMode |
getset |
◆ TimelineSpan
virtual TimeSpan VideoOS.Platform.Client.VideoControl.TimelineSpan |
getset |
◆ WindowId
Guid VideoOS.Platform.Client.VideoControl.WindowId |
getprotected set |
◆ PlaybackTimeChanged
virtual EventHandler VideoOS.Platform.Client.VideoControl.PlaybackTimeChanged |
◆ SelectedCameraChanged
EventHandler VideoOS.Platform.Client.VideoControl.SelectedCameraChanged |
abstract |
