Classes | |
class | ConnectResult |
Type representing the result of a call to HidInstance.ConnectAsync. More... | |
class | HidAxisInput |
Class representing HID axis input (joystick axis, mouse wheel, etc.) More... | |
class | HidAxisValueChangedEventArgs |
Event arguments for an axis value change. More... | |
class | HidBoolConfigurationProperty |
Boolean configuration property for a HidInstance.
class | HidButtonInput |
Class representing HID button (joystick button, keyboard key, etc.) More... | |
class | HidButtonValueChangedEventArgs |
Event arguments for a button value change. More... | |
class | HidButtonValueData |
Class representing a button pressed value with optional dynamic parameters. Class used to signal that button has been pressed or released. Class can contain a dynamic parameters string. The dynamic parameters are prepared by the plug-in and can, for example, represent the key sequence typed into a key pad before pressing the command button. More... | |
class | HidConfigurationProperty |
Abstract base class for a HID configuration property. Configuration properties are used when creating/connecting to a HidInstance. More... | |
class | HidConfigurationPropertyCollection |
class | HidConfigurationPropertySerializer |
class | HidEnumConfigurationProperty |
Enumeration configuration property for a HidInstance.
class | HidInput |
Base class for a Human Interface Device (HID) input. Class has unique ID, user-friendly Name and default ActionId. The HID input element can be associated with an action, that will be executed by the environment when the input value changes. More... | |
class | HidInstance |
A Human Interface Device (HID) plugin is very similar to the BackgroundPlugin with few members added to service human interface devices (keyboards, joysticks, trackballs, etc.). For more information, refer into the BackgroundPlugin documentation. More... | |
class | HidIntConfigurationProperty |
Integer configuration property for a HidInstance.
class | HidPlugin |
Human Interface Device (HID) plugin base class. Inherit from this class to create a new HID plugin. HID instances created by the plugin are exposed as joysticks in the Environment. More... | |
class | HidSliderInput |
Class representing HID slider input (zoom, speaker volume slider, etc.). More... | |
class | HidSliderValueChangedEventArgs |
Event arguments for a slider value change. More... | |
class | HidStringConfigurationProperty |
String configuration property for a HidInstance.
class | HidValueChangedEventArgs |
Base class for HID input notifications. More... | |
class | InstanceDiscoveryEventArgs |
Event arguments used when a new instance is discovered/undiscovered. | |
