VideoOS.Platform.Search.FilterValues.DoubleRangeFilterValue Class Reference
Search filter value representing a range (of doubles) selection. More...
Inheritance diagram for VideoOS.Platform.Search.FilterValues.DoubleRangeFilterValue:
VideoOS.Platform.Search.FilterValues.FilterValueBase
Public Member Functions
override bool Deserialize (string data)
 Restore filter value from the string.
override string FallbackDisplayValue ()
 Fallback value displayed in the UI if SearchFilter.GetDisplayValue is not overridden in the search filter.
override string Serialize ()
 Save filter value into a string.
- Public Member Functions inherited from VideoOS.Platform.Search.FilterValues.FilterValueBase
 Fallback value displayed in the UI if Search.SearchFilter.GetDisplayValue is not overridden in the search filter.
string Serialize ()
Properties
double High [get, set]
 The range high value.
double Low [get, set]
 The range low value.
- Properties inherited from VideoOS.Platform.Search.FilterValues.FilterValueBase
Additional Inherited Members
- Protected Member Functions inherited from VideoOS.Platform.Search.FilterValues.FilterValueBase
void FireChangedEvent ()
 Fires the Changed event which indicates the search filter value has changed.
- Events inherited from VideoOS.Platform.Search.FilterValues.FilterValueBase
EventHandler Changed
 Event fired when the search filter value changes.
Detailed Description
Member Function Documentation
◆ Deserialize()
override bool VideoOS.Platform.Search.FilterValues.DoubleRangeFilterValue.Deserialize ( string data)
inline
Parameters
dataString representation of the filter value.
Returns
True if successfully deserialized. False otherwise.
◆ FallbackDisplayValue()
override string VideoOS.Platform.Search.FilterValues.DoubleRangeFilterValue.FallbackDisplayValue ( )
inline
Returns
A (fallback) string representation of the filter value to be displayed in a graphical user interface.
◆ Serialize()
override string VideoOS.Platform.Search.FilterValues.DoubleRangeFilterValue.Serialize ( )
inline
Returns
Property Documentation
◆ High
double VideoOS.Platform.Search.FilterValues.DoubleRangeFilterValue.High
getset
◆ Low
double VideoOS.Platform.Search.FilterValues.DoubleRangeFilterValue.Low
getset
