Represents a workspace toolbar plug-in group. Used for grouping workspace toolbar plug-ins. If there are no plug-ins or sub groups under a group, then the group won't be shown.
More...
Guid | Id [get] |
| Gets the unique id identifying this plug-in group.
virtual ? Guid | ParentGroupId [get] |
| Gets parent group id of this workspace toolbar plug-in group. If it has a value, this group will be put under the group with this id as a subgroup. If it is null(default) or a group with this id is not defined, then the group won't be put under any other group. When having sub-groups under groups, it is recommended NOT to have more than the depth of 3 levels, as it will provide poor user experience in Smart Client.
string | Title [get, protected set] |
| Gets and sets the toolbar plug-in group title.
string | Tooltip [get, protected set] |
| Gets and sets the toolbar plug-in group tooltip.
void | ClearProperties () |
| Clear property table.
virtual void | Deserialize (XmlNode xmlNode) |
| Deserializes the class item from xml format.
string | GetProperty (string key) |
| Gets a named (key) property value from the property list. Null is returned of the property does not exists.
ICollection | GetPropertyKeys () |
| Gets all the keys in the property collection.
object | GetTemporaryProperty (string key) |
| Gets a named (key) temporary property value from the property list. Null is returned of the property does not exists.
| PropertyClass () |
| Constructs a PropertyClass item.
virtual void | Serialize (System.Xml.XmlTextWriter xmlTextWriter) |
| Serializes the class item into xml format.
virtual String | SerializeToString () |
| Create a XmlNode containing the property dictionary, returned as a String.
virtual XmlNode | SerializeToXmlNode () |
void | SetProperty (string key, string value) |
| Sets a named (key) property value in the property list. The property value is updated if the property exists.
void | SetTemporaryProperty (string key, object value) |
| Sets a named (key) temporary property value in the property list. The property value is updated if the property exists. Temporary will not be serialized (stored)
SortedList | _properties = new SortedList() |
| The key-value collection holding the properties.
SortedList | _temporaryProperties = new SortedList() |
| The key-value collection holding the temporary properties. Temporary will not be serialized (stored)
