Web Samples
Video Push Sample
The Video Push sample demonstrates how to push video from your device to the Mobile Server. For the purposes of the sample a static source of video with dynamically changing frames is used. A real source can be implemented by modifying the "initializeSourceCanvas" function.
Note: Before starting the sample you need to set up and configure a video push channel in the management client.
The video push sample can be found under .\XPMobileSdk\Web\Samples\VideoPush.
