Taking video stream from browser
var video = document.getElementById('videoVideoPush');
if (navigator.mediaDevices.getUserMedia) {
navigator.mediaDevices.getUserMedia({ video: true, audio: false }).then(onSuccess).catch(onError);
else {
navigator.getUserMedia = navigator.getUserMedia || navigator.webkitGetUserMedia || navigator.mozGetUserMedia;
if (navigator.getUserMedia) {
navigator.getUserMedia({ video: true, audio: false }, onSuccess, onError);
} else {
console.log("Video push not supported!");
function onSuccess(mediaStream) {
video.onloadedmetadata = function (event) {
video.onloadedmetadata = function () { };
video.play();
video.ontimeupdate = function () {
video.ontimeupdate = function () { };
video.src = window.URL.createObjectURL(mediaStream);
function onError(error) {
console.log(error.name);
Send command to the server to prepare URL for the upload
var requestStreamXMLMessage = generateXMLMessage({
sequenceId: 1, // just a random number, we are not going to track the sequenceId
connectionId: connect.connectionId,
command: 'RequestStream',
inputParams: {
SignalType: 'Upload',
ByteOrder: 'Network'
sendCommandRequest(requestStreamXMLMessage, function (response) {
var paramsNodes = response.querySelectorAll('Param');
for (var i = 0; i < paramsNodes.length; i++) {
videoPushParams[paramsNodes[i].getAttribute('Name')] = paramsNodes[i].getAttribute('Value');
Taking screenshot from the video tag through canvas
var width = video.videoWidth;
var height = video.videoHeight;
var canvasContext = canvas.getContext('2d');
canvasContext.canvas.width = width;
canvasContext.canvas.height = height;
canvasContext.drawImage(video, 0, 0, width, height);
send(canvas.toDataURL("image/jpeg", 0.9));
Packing the frame with video headers and send it to the server
function send(imageData) {
var bytesArray = Bytes.fromBase64(imageData);
var buffer = new ArrayBuffer(headerSize + bytesArray.length);
var bufferView = new Uint8Array(buffer);
// Header
bufferView.set(Bytes.fromGuid(videoPushParams.VideoId, 16)); // Video id
bufferView.set(Bytes.fromInt(new Date().getTime(), 8), 16); // Timestamp
bufferView.set(Bytes.fromInt(++counter, 4), 24); // Frame count
bufferView.set(Bytes.fromInt(bytesArray.length, 4), 28); // Frame size in bytes
bufferView.set(Bytes.fromInt(headerSize, 2), 32); // Header size in bytes
bufferView.set(Bytes.fromInt(0, 2), 34); // Header extension flags
// Data
bufferView.set(bytesArray, headerSize);
AjaxRequest(videoPushParams.StreamId, function () {}, buffer);
Bite parser
var Bytes = new function () {
var fromInt = function (integer, bytes) {
return fromHex(integer.toString(16), bytes);
var fromGuid = function (guid, bytes) {
return fromHex(guid.replace(/[^a-f0-9]/gi, ''), bytes);
var fromBase64 = function (base64, bytes) {
var string = atob(base64.replace(/^.*?,/, '')).slice(- bytes);
var array = new Array(bytes ? bytes - string.length : 0);
for (var i = 0; i < string.length; i++)
array.push(string.charCodeAt(i));
return array;
var fromHex = function (hex, bytes) {
hex = hex.length % 2 ? "0" + hex : hex;
var numbers = hex.match(/../g).splice(- bytes);
var array = new Array(bytes ? bytes - numbers.length : 0);
array.push.apply(array, numbers);
array.forEach(function (item, index) {
array[index] = parseInt(item || 0, 16);
return array;
return {
fromInt: fromInt,
fromGuid: fromGuid,
fromBase64: fromBase64,
fromHex: fromHex
