Assuming videoID = "f3cad68b-8692-4068-a79b-fdfd58665699" has been obtained from OutputParams of one RequestStream invocation, you can proceed like this:
httpRequest.open('POST','http://mobileserver.name:8081/Video/f3cad68b-8692-4068-a79b-fdfd58665699');
httpRequest
.responseType = 'arraybuffer';
httpRequest
.send(null);
to request a video frame. Upon successful completion httpRequest.response will have the frame encoded as an ArrayBuffer object.
You need an ArrayBufferView to access data in the ArrayBuffer. Considering the frame layout from chapter 5, we’ll use this library https://github.com/vjeux/jDataView to show a frame decoding example.
var response = httpRequest.response;
var
dataView = new jDataView(response, 0, response.length, true);
var
uuid = dataView.getUUID();
var
frame = {};
var
tsBytes = dataView.getArray(8);
var
ts = 0;
for
(var i = 0; i < 8; i ++)
ts
+= tsBytes[i] * Math.pow(2, 8 * i);
frame
.timestamp = new Date(ts);
frame
.frameNumber = dataView.getUint32();
frame
.dataSize    = dataView.getUint32();
frame
.headerSize  = dataView.getUint16();
var headerExtensions = dataView.getUint16();
frame
.hasSizeInformation          = headerExtensions  & 0x01;
frame
.hasLiveInformation          = headerExtensions  & 0x02;
frame
.hasPlaybackInformation      = headerExtensions   & 0x04;
if (frame.hasSizeInformation) {
frame
.sizeInfo = {sourceSize: {}, sourceCrop: {}, destinationSize: {}};
frame
.sizeInfo.sourceSize.width           = dataView.getUint32();
frame
.sizeInfo.sourceSize.height          = dataView.getUint32();
frame
.sizeInfo.sourceCrop.left            = dataView.getUint32();
frame
.sizeInfo.sourceCrop.top             = dataView.getUint32();
frame
.sizeInfo.sourceCrop.right           = dataView.getUint32();
frame
.sizeInfo.sourceCrop.bottom          = dataView.getUint32();
frame
.sizeInfo.destinationSize.width      = dataView.getUint32();
frame
.sizeInfo.destinationSize.height     = dataView.getUint32();
frame
.sizeInfo.destinationSize.left       = dataView.getUint32();
frame
.sizeInfo.destinationSize.top        = dataView.getUint32();
frame
.sizeInfo.destinationSize.right      = dataView.getUint32();
frame
.sizeInfo.destinationSize.bottom     = dataView.getUint32();
if (frame.hasLiveInformation) {
frame
.currentLiveEvents           = dataView.getUint32();
frame
.changedLiveEvents           = dataView.getUint32();
if (frame.hasPlaybackInformation) {
frame
.currentPlaybackEvents     = dataView.getUint32();
frame
.changedPlaybackEvents     = dataView.getUint32();
if (frame.dataSize > 0) {
dataView
.seek(frame.headerSize);
var darr = dataView.getArray(frame.dataSize);
frame
.imageData = 'data:image/jpeg;base64,' + Base64.encodeArray(darr);
Base64 implementation here: http://www.webtoolkit.info/javascript-base64.html
<img src = ‘frame.imageData’<>
will render the image.
