Introduction
Introduction to MIP SDK 2024 R2
Component integrations
Environment.AddServerOAuth(bool, Uri, ITokenCache, bool)method has been removed. UseEnvironment.AddServerOAuth(bool, Uri, IMipTokenCache, bool)instead.
Driver framework
Virtual
GetStreamInformationmethod has been added toSessionEnabledStreamManagerin order to support adaptive streaming. Override this method in order to provide information about current resolution provided by the stream.
Configuration API
- Mail notification profiles can now be added, updated, and removed, and mail server settings can be configured.
- Bookmarks can now be added, read, updated, and removed.
- Registered services can now be added, read, and removed.
- Task for removing a recording server has been added.
- Evidence lock profiles can now be added, updated, and removed.
- Underlying view can be read for a video wall monitor.
Items of type
ValueTypes.DateTimeTypehas been aligned to all use the standard round-trip pattern (e.g. 2009-06-15T13:45:30.0000000Z).
RESTful APIs
- RESTful Config API:
- Tasks for going to PTZ presets, activating, deactivating and triggering outputs, and getting and setting the absolute position of cameras have been added.
Two endpoints for reading what permissions you have on XProtect have been added:
The endpoint
/securityNamespacesis used to see what security namespaces are defined, e.g. what the ID is and what security actions exists and their bit position (as it is used in theeffectivePermissionsAPI).The endpoint
/effectivePermissionsis used to see what permissions the caller has, when combining the settings from the overall security settings and multiple role settings. The result is a dictionary of object IDs and a bitmask of permissions within the security namespace being asked for, e.g. 'cameras'. Only the object IDs the caller has read access to are returned. - The endpoint
/registeredServicesfor managing registered services has been added.
- RESTful APIs for tagging video sequences have been added:
- The endpoint
/bookmarksfor managing bookmarks. - The endpoint
/evidenceLocksfor managing evidence locks.
- The endpoint
- No longer in beta:
- RESTful Events API
- RESTful Alarms API
WebSocket APIs
- WebSocket Messages API
Smart Client
ImageViewerAddOnextended with propertyStreamIdproviding access to reading and changing the selected stream. Similarly ViewItem instance items returned byConfiguration.GetItemswill containCurrentStreamIdreadonly property in thePropertiesdictionary.
Samples
The following samples have been changed:
Smart Client ImageViewerAddOnhas been extended with functionality that demonstrates reading and changing the selected stream of the currently selected camera view item. -
Demo Driverhas been extended with support for adaptive streaming. -
Config Updatedhas been removed. Instead use the Configuration Access sample. The Configuration Access sample shows the recommended method of keeping the configuration updated automatically in a MIP SDK application, automatically updating the configuration without requiring an restart.
Fixed issues
- Matching of HTTP headers for the WebRTC signaling were case-sensitive.
Calling
Savemethod twice on sameConfigurationItems.Viewobject would cause anArgumentMIPExceptionto be thrown.
