External IDP and Milestone Federated Architecture
Milestone XProtect 2023 R3 supports a Milestone Federated Architecture setup with an option to use an external IDP to log in from sites within the federated hierarchy.
Current Scope
The current functionality allows users of XProtect Smart Client to log in from a federated site via an external IDP.
Prerequisites
Requirements
Connectivity
To enable login on all levels in the hierarchy, a site needs to be able to connect to all its parents.
Trusted Sites
To log in from a parent site in Milestone Federated Architecture with an external IDP user, the child site must be set up to trust the parent. The trusted sites constitute the collection of sites that the current site trusts for login to the federated hierarchy. See “Set up trusted sites” on how to set up the trust.
Certificate Setup
For a secure VMS setup, the child site must trust the certificate configured on the parent site. For more information about certificates, see the Milestone Certificates Guide.
External Provider Naming
To be able to map between sites, the display name in the configuration of the external IDP must be the same across each site in the federated hierarchy.
User Provisioning
When a user logs in to the federated hierarchy via an external IDP, the user will automatically be provisioned on each site in the hierarchy. To align usernames across sites, the external provider should be set up to resolve usernames in the same manner.
Set Up Trusted Sites
Trusted sites can also be scripted using following PowerShell script.
            # Global variables
            $server_url = "https://<machine-fqdn>"
            $token_url = "$server_url/idp/connect/token"
            function Get-AccessToken {
                param (
                [string]$grant_type,
                [string]$scope,
                [string]$client_id,
                [string]$client_secret = ""
                $body = @{
                grant_type = $grant_type
                scope = $scope
                client_id = $client_id
                if ($client_secret) {
                $body.client_secret = $client_secret
                $response = Invoke-WebRequest -Uri $token_url -Method Post -Body $body -UseDefaultCredentials:($grant_type -eq "windows_auth")
                $accessToken = ($response.Content | ConvertFrom-Json).access_token
                return $accessToken
            function Invoke-ApiRequest {
                param (
                [string]$method,
                [string]$endpoint,
                [string]$accessToken,
                [object]$body = $null
                $headers = @{
                Authorization = "Bearer $accessToken"
                $params = @{
                Method = $method
                Uri = "$server_url/api/idp/api/$endpoint"
                Headers = $headers
                ContentType = "application/json"
                if ($body) {
                $params.Body = (ConvertTo-Json $body)
                $response = Invoke-RestMethod @params
                return $response
            function Get-RegisteredClients {
                param ([string]$accessToken)
                return Invoke-ApiRequest -method Get -endpoint "clients" -accessToken $accessToken
            function Get-ClientsWithScope {
                param (
                [string]$scope
                $clients = Get-RegisteredClients -accessToken $accessToken
                return $clients | Where-Object { $_.clientScopes -eq $scope }
            function Add-UpdateClient {
                param (
                [string]$clientId,
                [string]$clientName,
                [string[]]$clientScopes,
                [string[]]$clientGrantTypes
                $clientData = @{
                ClientName = $clientName
                ClientScopes = $clientScopes
                ClientGrantTypes = $clientGrantTypes
                return Invoke-ApiRequest -method Put -endpoint "clients/$clientId" -accessToken $accessToken -body $clientData
            function Get-TrustedIssuers {
                return Invoke-ApiRequest -method Get -endpoint "trustedIssuers" -accessToken $accessToken
                function Add-TrustedIssuer {
                param (
                [string]$address,
                [string]$issuer
                $data = @{
                Address = $address
                Issuer = $issuer
                return Invoke-ApiRequest -method Post -endpoint "trustedIssuers" -accessToken $accessToken -body $data
            function Delete-TrustedIssuer {
                param (
                [string]$id
                return Invoke-ApiRequest -method Delete -endpoint "trustedIssuers/$id" -accessToken $accessToken
            function Add-Trust
                param (
                $address = Read-Host 'what is the trusted issue address (parent site)? (the address is case sensitive)'
                $trustedIssuer = Add-TrustedIssuer -accessToken $accessToken -address $address -issuer $address
                "Trusted issuer added:"
                $trustedIssuer | Format-List
                param (
                # Get input
                $trustedIssuers = Get-TrustedIssuers -accessToken $accessToken
                "Trusted issuers"
                $trustedIssuers | Format-List
                $id = Read-Host 'choose which issuer to delete. Specify ID'
                Delete-TrustedIssuer -accessToken $accessToken -id $id
            # Execution
            $stop = 1
            while($stop -eq 1)
                # Get input
                $operation = Read-Host "Add(0), delete(1) or list(2) trusted issuer(s)"
                # Get access token for initial operations
                $initialAccessToken = Get-AccessToken -grant_type "windows_auth" -scope "write:client" -client_id "winauthclient"
                # Get list of registered clients
                $registeredClients = Get-RegisteredClients -accessToken $initialAccessToken
                #$registeredClients | Format-List
                # Get clients with IDP management scope
                $idpManagementClients = Get-ClientsWithScope -accessToken $initialAccessToken -scope "idp_management"
                #$idpManagementClients | Format-List
                # Add a client with IDP management scopes
                $newClient = Add-UpdateClient -accessToken $initialAccessToken -clientId "TrustedIssuerClient" -clientName "TrustedIssuerClient" -clientScopes @("idp_management") -clientGrantTypes @("client_credentials")
                #$newClient.data | Format-List
                # Get access token for the test client and Add or Delete trust
                $accessToken = Get-AccessToken -grant_type "client_credentials" -client_id "TrustedIssuerClient" -client_secret $newClient.data.secret
                if($operation -eq 0)
                    Add-Trust -accessToken $accessToken
                if($operation -eq 1)
                    Delete-Trust -accessToken $accessToken
                # Get all trusted issuers
                "All trusted issuers"
                $stop = Read-Host "Would you like to do more (0/1)"
Trusted Issuer Fields: Issuer and Address
A trusted issuer has two fields: "Issuer" and "Address".
