Control of Milestone XProtect
You can make integrations to control devices, control the recordings, and control output triggers.
Use the control integration to control where a PTZ camera should be moved via presets or joystick-like commands. You can use it to trigger auxiliary outputs for turning features on and off in a device (for example, a wiper).
You can also use the control integration for controlling when to record video, retrieve edge recordings or start a rule.
Following is an overview of the system architecture and functionality you want to control in your Milestone XProtect video management software.
The illustration shows the three areas of control.
