VideoOS.Platform.ConfigurationItems.UpdateHardwareServerTask Class Reference
Contains the result from a Hardware.UpdateHardware() call. More...
Inheritance diagram for VideoOS.Platform.ConfigurationItems.UpdateHardwareServerTask:
VideoOS.Platform.ConfigurationItems.ServerTask
Public Member Functions
ServerTask Execute ()
 Call this method to let the server execute when the properties have been updated.
The returned ServerTask can be used to inspect the result.
- Public Member Functions inherited from VideoOS.Platform.ConfigurationItems.ServerTask
ServerTask ExecuteDefault ()
 Will execute the first available method. Can be called when multiple steps are involved in changing values in the properties.
ServerTask ExecuteMethod (string methodId)
 Execute the provided method. The method id must be one of the defined values in the Methods property.
string GetProperty (string key)
 Return a property value as string, if key is not found the return value will be null.
ICollection< string > GetPropertyKeys ()
 Gets a collection of all available property keys.
void GetTask (string path)
 Use this method once, when the InvokeResult has placed the task path in a property with another name than 'Path'.
List< ValueTypeInfoGetValueTypeInfoList (string propertyKey)
 Gets a list of defined ValueTypeInfo for a given property.
If no ValueTypeInfo is available, an empty list is returned.
void SetProperty (string key, string content)
 Sets the value of a property (all is string format here)
void UpdateState ()
 Calls the server to get the fields updated, when the progress is < 100.
ValidateResult ValidateItem ()
 Validate the current content.
Properties
bool AnyEventsUpdated [get]
 Indicate if any events on the hardware has changed.
string HardwareName [get]
 Name of hardware being updated.
string HardwarePath [get]
 Path of hardware beging updated.
long SessionDataId [get, set]
 The ID is returned as result for 1. time call, and need to be used for 2. time call (The apply step)
ReadOnlyCollection< UpdateHardwareDetailUpdateHardwareDetails [get]
 Contains details for each device/item on the hardware.
- Properties inherited from VideoOS.Platform.ConfigurationItems.ServerTask
String ErrorCode [get]
 If state is Error the ErrorCode explains what went wrong.
String ErrorText [get]
 When state is Error the ErrorState TBD.
string ItemType [get]
 Returns the ItemType of the underlayng ConfigurationItem, usually InvokeResult or InvokeInfo.
Collection< string > Methods [get]
 The available methods for this task.
string Path [get]
 The path of an item, when relevant. Usually available after adding a ConfigurationItem.
int Progress [get]
 Defines the progress of the server task. When Progress is 100, or state is Success or Error - the task is complete.
StateEnum State [get]
 Defines the current state of this task.
Detailed Description
Return value from the detection step will be a dataSessionId and a list of devices with detected changes Notice that Path value is incorrect for ADDED devices in this step. (Contains Guid.Empty)
Return value from the apply step will be a list of the changed devices/items
Member Function Documentation
◆ Execute()
ServerTask VideoOS.Platform.ConfigurationItems.UpdateHardwareServerTask.Execute ( )
inline
Property Documentation
◆ AnyEventsUpdated
bool VideoOS.Platform.ConfigurationItems.UpdateHardwareServerTask.AnyEventsUpdated
get
◆ HardwareName
string VideoOS.Platform.ConfigurationItems.UpdateHardwareServerTask.HardwareName
get
◆ HardwarePath
string VideoOS.Platform.ConfigurationItems.UpdateHardwareServerTask.HardwarePath
get
◆ SessionDataId
long VideoOS.Platform.ConfigurationItems.UpdateHardwareServerTask.SessionDataId
getset
◆ UpdateHardwareDetails
ReadOnlyCollection<UpdateHardwareDetail> VideoOS.Platform.ConfigurationItems.UpdateHardwareServerTask.UpdateHardwareDetails
get
