Update firmware. More...
Public Member Functions | |
| ServerTask | Execute () |
| Call this method to let the server execute when the properties have been updated. The returned ServerTask can be used to inspect the result. | |
Public Member Functions inherited from VideoOS.Platform.ConfigurationItems.ServerTask | |
| ServerTask | ExecuteDefault () |
| Will execute the first available method. Can be called when multiple steps are involved in changing values in the properties. | |
| ServerTask | ExecuteMethod (string methodId) |
| Execute the provided method. The method id must be one of the defined values in the Methods property. | |
| string | GetProperty (string key) |
| Return a property value as string, if key is not found the return value will be null. | |
| ICollection< string > | GetPropertyKeys () |
| Gets a collection of all available property keys. | |
| void | GetTask (string path) |
| Use this method once, when the InvokeResult has placed the task path in a property with another name than 'Path'. | |
| List< ValueTypeInfo > | GetValueTypeInfoList (string propertyKey) |
| Gets a list of defined ValueTypeInfo for a given property. If no ValueTypeInfo is available, an empty list is returned. | |
| void | SetProperty (string key, string content) |
| Sets the value of a property (all is string format here) | |
| void | UpdateState () |
| Calls the server to get the fields updated, when the progress is < 100. | |
| ValidateResult | ValidateItem () |
| Validate the current content. | |
Properties | |
| string | StorageId [get, set] |
| Storage ID. The storage ID of the uploaded file. | |
Properties inherited from VideoOS.Platform.ConfigurationItems.ServerTask | |
| String | ErrorCode [get] |
| If state is Error the ErrorCode explains what went wrong. | |
| String | ErrorText [get] |
| When state is Error the ErrorState TBD. | |
| string | ItemType [get] |
| Returns the ItemType of the underlayng ConfigurationItem, usually InvokeResult or InvokeInfo. | |
| Collection< string > | Methods [get] |
| The available methods for this task. | |
| string | Path [get] |
| The path of an item, when relevant. Usually available after adding a ConfigurationItem. | |
| int | Progress [get] |
| Defines the progress of the server task. When Progress is 100, or state is Success or Error - the task is complete. | |
| StateEnum | State [get] |
| Defines the current state of this task. | |
Update firmware.
inline |
getset |
