VideoOS.Platform.ConfigurationItems.Hardware Class Reference
More...
Inheritance diagram for VideoOS.Platform.ConfigurationItems.Hardware:
VideoOS.Platform.ConfigurationItems.IConfigurationItem VideoOS.Platform.ConfigurationItems.IConfigurationItem VideoOS.Platform.ConfigurationItems.IConfigurationChildItem VideoOS.Platform.ConfigurationItems.IConfigurationChildItem
Public Member Functions
ChangePasswordHardwareServerTask ChangePasswordHardware ()
 Change hardware password.
ServerTask ChangePasswordHardware (String password)
Please consider using secure version taking SecureString instead.
ServerTask ChangePasswordHardware (System.Security.SecureString password)
ServerTask ChangePasswordHardware (System.Security.SecureString password, bool updatePasswordOnDevice)
 Hardware (FQID fqid)
 Construct the class from a MIP FQID - note that not all configuration items have a corresponding FQID.
 Hardware (ServerId serverId, ConfigurationItem hardware)
 Construct the class from serverId of the Management Server that owns the configuration, and the already returned ConfigurationItem.
 Hardware (ServerId serverId, string path)
 Construct the class from serverId of the Management Server that owns the configuration, and the path of the item.
MoveHardwareServerTask MoveHardware ()
 Move hardware.
ServerTask MoveHardware (String destinationRecordingServer)
 Move hardware.
ServerTask ReadPasswordHardware ()
 Read hardware password.
ReplaceHardwareServerTask ReplaceHardware ()
 Replace hardware.
ServerTask ReplaceHardware (String address, int port, bool useHttps, int httpsPort, String userName, System.Security.SecureString password, String driver, String customDriverData, bool allowDeletingDisabledDevices)
 Replace hardware.
UpdateFirmwareHardwareServerTask UpdateFirmwareHardware ()
 Update firmware.
ServerTask UpdateFirmwareHardware (String storageId)
 Update firmware.
UpdateHardwareServerTask UpdateHardware ()
 Update hardware - detection step.
UpdateHardwareServerTask UpdateHardware (long sessionDataId)
 Update hardware. When sessionDataId is zero - performs a detection, otherwise the sessionDataId is set to the value returned in detection step - and will apply the detected changes.
- Public Member Functions inherited from VideoOS.Platform.ConfigurationItems.IConfigurationItem
void ClearChildrenCache ()
 Clear the internal cache of children. Can be used to force a new set of children to be fetched from the server at next access.
ServerTask ExecuteMethod (string methodId)
 Execute the provided method. The method id must be one of the defined values in the Methods property.
void FillChildren (string[] itemTypes)
 Fill all children and grand-children - as long as the itemtype is contained in itemType parameter.
void FillChildren (string[] itemTypes, ItemFilter[] itemFilters)
 Fill all children and grand-children - as long as the itemtype is contained in itemType parameter and filters match. If multiple filters are defined for same itemtype, all must match for the item to be included ('and' operation).
If no filter is defined for an ItemType, then all items of that type is filled.
void Save ()
 Will save all updated values to server.
ValidateResult ValidateItem ()
 Validate the current content.
- Public Member Functions inherited from VideoOS.Platform.ConfigurationItems.IConfigurationChildItem
string GetProperty (string key)
 Return a property value as string, if key is not found the return value will be null.
ICollection< string > GetPropertyKeys ()
 Get a collection of all available property keys.
List< ValueTypeInfoGetValueTypeInfoList (string propertyKey)
 Get defined ValueTypeInfo for a given property. If no ValueTypeInfo is available, an empty list is returned.
void SetProperty (string key, string content)
 Sets the value of a property (all is string format here)
override string ToString ()
 Display the 'DisplayName' is the default ToString()
Properties
string Address [get, set]
 Address. The base address of the hardware. If the property HttpsEnabled exists in the general settings of this hardware and has the value Yes, the address should be modified to use HTTPS and the port defined in the property named HttpsPort under general settings.
CameraFolder CameraFolder [get]
 Return the single folder item of the given ItemType.
CustomPropertiesFolder CustomPropertiesFolder [get]
bool Enabled [get, set]
 Indicate if this item is active in the VMS system, e.g. enabled.
HardwareDeviceEventFolder HardwareDeviceEventFolder [get]
String HardwareDriverPath [get]
 Path. Contains the path/ID of the device driver used for the hardware. Driver can be looked up under the recording server.
HardwareDriverSettingsFolder HardwareDriverSettingsFolder [get]
HardwarePtzSettingsFolder HardwarePtzSettingsFolder [get]
string Id [get]
 ID.
InputEventFolder InputEventFolder [get]
DateTime LastModified [get]
 Last modified.
MetadataFolder MetadataFolder [get]
MicrophoneFolder MicrophoneFolder [get]
string Model [get]
 Model.
OutputFolder OutputFolder [get]
DateTime PasswordLastModified [get]
 Password last changed.
SpeakerFolder SpeakerFolder [get]
string UserName [get, set]
 User name.
- Properties inherited from VideoOS.Platform.ConfigurationItems.IConfigurationItem
Guid Guid [get]
 Returns the id property or part of the path, when available. When no id is available this will be Guid.Empty. This is relevant for some items of ItemCategory.ChildItem where no property with key = "Id" exists and path does not contains a guid.
Collection< string > Methods [get]
 The available methods for this class.
- Properties inherited from VideoOS.Platform.ConfigurationItems.IConfigurationChildItem
string Description [get, set]
 Description.
virtual string DisplayName [get]
 Name of this ConfigurationItem in user readable format. Usually the same as property with key = "Name".
string ItemCategory [get]
 Return the item category for this item. This can be used to understand how multiple items are fetched and saved together. Only ItemCategory == 'Item' can be saved.
string Name [get, set]
 Name.
string ParentItemPath [get]
 Get hold of the next real parent path, e.g. skip any 'Folder' type parent.
string ParentPath [get]
 The path for the parent of this ConfigurationItem.
string Path [get]
 The identification of this item.
ServerId ServerId [get, set]
 Contains the ServerId of the Management Server holding this item.
Detailed Description
Constructor & Destructor Documentation
◆ Hardware() [1/3]
VideoOS.Platform.ConfigurationItems.Hardware.Hardware ( ServerId serverId,
ConfigurationItem hardware )
inline
Parameters
serverIdIdentify the Management Server that owns the configuration
hardwareThe ConfigurationItem returned from elsewhere
Exceptions
ArgumentMIPExceptionWhen LoginSettings not found for serverId
◆ Hardware() [2/3]
string path )
inline
This construction will contact the server and read the specified item.
Parameters
pathThe path of a specific item
Exceptions
MIPExceptionRepresents a number of possible exceptions. Possible exceptions can be found via the inherited exceptions - like PathNotFoundMIPException
◆ Hardware() [3/3]
VideoOS.Platform.ConfigurationItems.Hardware.Hardware ( FQID fqid)
inline
Parameters
fqidIdentify the MIP item
Exceptions
Member Function Documentation
◆ ChangePasswordHardware() [1/4]
ChangePasswordHardwareServerTask VideoOS.Platform.ConfigurationItems.Hardware.ChangePasswordHardware ( )
inline
◆ ChangePasswordHardware() [2/4]
ServerTask VideoOS.Platform.ConfigurationItems.Hardware.ChangePasswordHardware ( String password)
inline
Parameters
passwordPassword
◆ ChangePasswordHardware() [3/4]
ServerTask VideoOS.Platform.ConfigurationItems.Hardware.ChangePasswordHardware ( System.Security.SecureString password)
inline
Parameters
passwordPassword
◆ ChangePasswordHardware() [4/4]
ServerTask VideoOS.Platform.ConfigurationItems.Hardware.ChangePasswordHardware ( System.Security.SecureString password,
bool updatePasswordOnDevice )
inline
Parameters
passwordPassword
updatePasswordOnDeviceUpdate password also on device. If checked the password will be changed in the system and on the hardware device itself
◆ MoveHardware() [1/2]
MoveHardwareServerTask VideoOS.Platform.ConfigurationItems.Hardware.MoveHardware ( )
inline
Move hardware.
◆ MoveHardware() [2/2]
ServerTask VideoOS.Platform.ConfigurationItems.Hardware.MoveHardware ( String destinationRecordingServer)
inline
Move hardware.
Parameters
destinationRecordingServerDestination recording server. The recording server that the hardware device is moved to.
◆ ReadPasswordHardware()
ServerTask VideoOS.Platform.ConfigurationItems.Hardware.ReadPasswordHardware ( )
inline
◆ ReplaceHardware() [1/2]
ReplaceHardwareServerTask VideoOS.Platform.ConfigurationItems.Hardware.ReplaceHardware ( )
inline
Replace hardware.
◆ ReplaceHardware() [2/2]
ServerTask VideoOS.Platform.ConfigurationItems.Hardware.ReplaceHardware ( String address,
int port,
bool useHttps,
int httpsPort,
String userName,
String driver,
bool allowDeletingDisabledDevices )
inline
Replace hardware.
Parameters
addressAddress. The IP address or host name of the new hardware.
portPort. The network port to use for communicating with the new hardware
useHttpsUse HTTPS. Communication with the new hardware must use HTTPS
httpsPortHTTPS port. Port to use for HTTPS communication with the new hardware
userNameUser name. User name to use with the new hardware
passwordPassword. Password to use with the new hardware
driverDriver. Driver number of the driver to use with the new hardware
customDriverDataCustom driver data. Custom driver data passed to the driver when obtaining information about the new hardware. Not supported for most drivers, so in most cases just leave it empty
allowDeletingDisabledDevicesAllow deleting disabled devices. Is the replace hardware task allowed to delete disabled devices if needed during the replace hardware operation
◆ UpdateFirmwareHardware() [1/2]
UpdateFirmwareHardwareServerTask VideoOS.Platform.ConfigurationItems.Hardware.UpdateFirmwareHardware ( )
inline
Update firmware.
◆ UpdateFirmwareHardware() [2/2]
ServerTask VideoOS.Platform.ConfigurationItems.Hardware.UpdateFirmwareHardware ( String storageId)
inline
Update firmware.
Parameters
storageIdStorage ID. The storage ID of the uploaded file
◆ UpdateHardware() [1/2]
UpdateHardwareServerTask VideoOS.Platform.ConfigurationItems.Hardware.UpdateHardware ( )
inline
◆ UpdateHardware() [2/2]
UpdateHardwareServerTask VideoOS.Platform.ConfigurationItems.Hardware.UpdateHardware ( long sessionDataId)
inline
Property Documentation
◆ Address
string VideoOS.Platform.ConfigurationItems.Hardware.Address
getset
◆ CameraFolder
CameraFolder VideoOS.Platform.ConfigurationItems.Hardware.CameraFolder
get
◆ CustomPropertiesFolder
CustomPropertiesFolder VideoOS.Platform.ConfigurationItems.Hardware.CustomPropertiesFolder
get
◆ Enabled
bool VideoOS.Platform.ConfigurationItems.Hardware.Enabled
getset
◆ HardwareDeviceEventFolder
HardwareDeviceEventFolder VideoOS.Platform.ConfigurationItems.Hardware.HardwareDeviceEventFolder
get
◆ HardwareDriverPath
String VideoOS.Platform.ConfigurationItems.Hardware.HardwareDriverPath
get
◆ HardwareDriverSettingsFolder
HardwareDriverSettingsFolder VideoOS.Platform.ConfigurationItems.Hardware.HardwareDriverSettingsFolder
get
◆ HardwarePtzSettingsFolder
HardwarePtzSettingsFolder VideoOS.Platform.ConfigurationItems.Hardware.HardwarePtzSettingsFolder
get
◆ Id
string VideoOS.Platform.ConfigurationItems.Hardware.Id
get
ID.
◆ InputEventFolder
InputEventFolder VideoOS.Platform.ConfigurationItems.Hardware.InputEventFolder
get
◆ LastModified
DateTime VideoOS.Platform.ConfigurationItems.Hardware.LastModified
get
Last modified.
◆ MetadataFolder
MetadataFolder VideoOS.Platform.ConfigurationItems.Hardware.MetadataFolder
get
◆ MicrophoneFolder
MicrophoneFolder VideoOS.Platform.ConfigurationItems.Hardware.MicrophoneFolder
get
◆ Model
string VideoOS.Platform.ConfigurationItems.Hardware.Model
get
Model.
◆ OutputFolder
OutputFolder VideoOS.Platform.ConfigurationItems.Hardware.OutputFolder
get
◆ PasswordLastModified
DateTime VideoOS.Platform.ConfigurationItems.Hardware.PasswordLastModified
get
◆ SpeakerFolder
SpeakerFolder VideoOS.Platform.ConfigurationItems.Hardware.SpeakerFolder
get
◆ UserName
string VideoOS.Platform.ConfigurationItems.Hardware.UserName
getset
User name.
