A serverTask (result) that also Contains a collection of classes, as a result of the executed task on the server.
More...
| Collection< IConfigurationChildItem > | ChildItemClassCollection [get] |
| | Contains a list of ConfigurationItem's, where they are of type ChildItem.
| Collection< IConfigurationItem > | ClassCollection [get] |
| | Contains a list of ConfigurationItem's.
| String | ErrorCode [get] |
| | If state is Error the ErrorCode explains what went wrong.
| String | ErrorText [get] |
| | When state is Error the ErrorState TBD.
| string | ItemType [get] |
| | Returns the ItemType of the underlayng ConfigurationItem, usually InvokeResult or InvokeInfo.
| Collection< string > | Methods [get] |
| | The available methods for this task.
| string | Path [get] |
| | The path of an item, when relevant. Usually available after adding a ConfigurationItem.
| int | Progress [get] |
| | Defines the progress of the server task. When Progress is 100, or state is Success or Error - the task is complete.
| StateEnum | State [get] |
| | Defines the current state of this task.
| ServerTask | ExecuteDefault () |
| | Will execute the first available method. Can be called when multiple steps are involved in changing values in the properties.
| ServerTask | ExecuteMethod (string methodId) |
| | Execute the provided method. The method id must be one of the defined values in the Methods property.
| string | GetProperty (string key) |
| | Return a property value as string, if key is not found the return value will be null.
| ICollection< string > | GetPropertyKeys () |
| | Gets a collection of all available property keys.
| void | GetTask (string path) |
| | Use this method once, when the InvokeResult has placed the task path in a property with another name than 'Path'.
| List< ValueTypeInfo > | GetValueTypeInfoList (string propertyKey) |
| | Gets a list of defined ValueTypeInfo for a given property.
If no ValueTypeInfo is available, an empty list is returned.
| void | SetProperty (string key, string content) |
| | Sets the value of a property (all is string format here)
| void | UpdateState () |
| | Calls the server to get the fields updated, when the progress is < 100.
| ValidateResult | ValidateItem () |
| | Validate the current content.
Is used for e.g. getting the devices using a specific Storage.
