VideoOS.Platform.ConfigurationItems.Camera Class Reference
More...
Inheritance diagram for VideoOS.Platform.ConfigurationItems.Camera:
VideoOS.Platform.ConfigurationItems.IConfigurationItem VideoOS.Platform.ConfigurationItems.IConfigurationChildItem
Public Member Functions
 Camera (FQID fqid)
 Construct the class from a MIP FQID - note that not all configuration items have a corresponding FQID.
 Camera (ServerId serverId, ConfigurationItem camera)
 Construct the class from serverId of the Management Server that owns the configuration, and the already returned ConfigurationItem.
 Camera (ServerId serverId, string path)
 Construct the class from serverId of the Management Server that owns the configuration, and the path of the item.
ChangeDeviceRecordingStorageServerTask ChangeDeviceRecordingStorage ()
 Change storage for device.
ServerTask ChangeDeviceRecordingStorage (String itemSelection, bool moveData)
ChangeSecurityPermissionsServerTask ChangeSecurityPermissions ()
 Edit permissions.
ServerTask ChangeSecurityPermissions (String userPath)
 Edit permissions.
ClassCollectionServerTask GetOtherRecordingServersWithMedia ()
 Get recording servers with media.
ClassCollectionServerTask GetOtherRecordingStoragesWithMedia ()
 [DEPRECATED] This function is deprecated and should not be used. As an alternative, use the value of the 'RecordingStorage' property to get the configured recording storage for the device.
ServerTask GetPtzAbsolutePosition ()
 Get absolute position.
ServerTask JpegGetLive (int width, int height)
 Get a single JPEG from live stream.
RetrieveEdgeStorageServerTask RetrieveEdgeStorage ()
 Retrieve recordings from edge storage.
ServerTask RetrieveEdgeStorage (DateTime startTime, DateTime endTime)
ServerTask RetrieveEdgeStorage (DateTime startTime, DateTime endTime, String identifier, Collection< string > relatedTasks)
ServerTask SendDriverCommand (string command, string parameter, int timeOut)
 Send driver command to device.
ServerTask SetPtzAbsolutePosition (double pan, double tilt, double zoom, double speed, bool allowRepeats)
 Set absolute position.
ServerTask TruncateStorage ()
 Delete all recordings for device on storage.
TruncateStorageOnOtherRecordingServerServerTask TruncateStorageOnOtherRecordingServer ()
 Delete all recordings for device on another recording server.
ServerTask TruncateStorageOnOtherRecordingServer (String itemSelection)
- Public Member Functions inherited from VideoOS.Platform.ConfigurationItems.IConfigurationItem
void ClearChildrenCache ()
 Clear the internal cache of children. Can be used to force a new set of children to be fetched from the server at next access.
ServerTask ExecuteMethod (string methodId)
 Execute the provided method. The method id must be one of the defined values in the Methods property.
void FillChildren (string[] itemTypes)
 Fill all children and grand-children - as long as the itemtype is contained in itemType parameter.
void FillChildren (string[] itemTypes, ItemFilter[] itemFilters)
 Fill all children and grand-children - as long as the itemtype is contained in itemType parameter and filters match. If multiple filters are defined for same itemtype, all must match for the item to be included ('and' operation).
If no filter is defined for an ItemType, then all items of that type is filled.
void Save ()
 Will save all updated values to server.
ValidateResult ValidateItem ()
 Validate the current content.
- Public Member Functions inherited from VideoOS.Platform.ConfigurationItems.IConfigurationChildItem
string GetProperty (string key)
 Return a property value as string, if key is not found the return value will be null.
ICollection< string > GetPropertyKeys ()
 Get a collection of all available property keys.
List< ValueTypeInfo > GetValueTypeInfoList (string propertyKey)
 Get defined ValueTypeInfo for a given property. If no ValueTypeInfo is available, an empty list is returned.
void SetProperty (string key, string content)
 Sets the value of a property (all is string format here)
override string ToString ()
 Display the 'DisplayName' is the default ToString()
Properties
int Channel [get]
 Channel.
ClientSettingsFolder ClientSettingsFolder [get]
 Return the single folder item of the given ItemType.
double CoverageDepth [get, set]
 Depth. Indicate the viewing depth of the device.
double CoverageDirection [get, set]
 Direction. Indicate the viewing direction of the device.
double CoverageFieldOfView [get, set]
 Field of view. Indicate the field of view of the device.
DateTime CreatedDate [get]
 [RESERVED] Reserved for future use
CustomPropertiesFolder CustomPropertiesFolder [get]
DeviceDriverSettingsFolder DeviceDriverSettingsFolder [get]
bool EdgeStorageEnabled [get, set]
 Remote recording enabled.
bool EdgeStoragePlaybackEnabled [get, set]
 Remote recording playback.
bool Enabled [get, set]
 Indicate if this item is active in the VMS system, e.g. enabled.
String FailoverSetting [get, set]
 Failover setting. Specify how the device is operating on a failover recording server. . Valid values are available in the FailoverSettingValues property dictionary.
Dictionary< string, string > FailoverSettingValues [get]
 A list of valid names/values for the FailoverSetting property.
FisheyeLensFolder FisheyeLensFolder [get]
string GisPoint [get, set]
 Device position. Device position. Position of device in longitude, latitude and potentially altitude.
The format is "POINT (LONGITUDE LATITUDE)" and if you want to clear the coordinates, the value to use is "POINT EMPTY".
Examples: "POINT (55.656932878513 12.3763545558449)" "POINT EMPTY"
Can also include altitude, if so the format is "POINT (LONGITUDE LATITUDE ALTITUDE)"
HardwareDeviceEventFolder HardwareDeviceEventFolder [get]
int Icon [get, set]
 Icon identifier. The relevant device icon to show in Smart Map. Values between 0-9 for cameras, 0-6 for input devices, 0-3 for microphones and 0-3 for outputs. If invalid value is given, Smart Map have a fallback icon.
string Id [get]
 ID.
DateTime LastModified [get]
 Last modified.
bool ManualRecordingTimeoutEnabled [get, set]
 Manual recording timeout enabled.
int ManualRecordingTimeoutMinutes [get, set]
 Manual recording timeout in minutes.
MotionDetectionFolder MotionDetectionFolder [get]
PatrollingProfileFolder PatrollingProfileFolder [get]
bool PrebufferEnabled [get, set]
 Prebuffer enabled.
bool PrebufferInMemory [get, set]
 Prebuffer in memory.
int PrebufferSeconds [get, set]
 Prebuffer seconds.
PrivacyProtectionFolder PrivacyProtectionFolder [get]
bool PtzEnabled [get]
 PTZ enabled.
PtzPresetFolder PtzPresetFolder [get]
bool RecordingEnabled [get, set]
 Recording enabled.
double RecordingFramerate [get, set]
 Recording frame rate.
String RecordingStorage [get]
 Path. Contains the path to the related recording storage.
bool RecordKeyframesOnly [get, set]
 Record keyframes only.
bool RecordOnRelatedDevices [get, set]
 Record on related devices.
string ShortName [get, set]
 Short name. Used as name in the user interface where appropriate.
ICollection< StreamChildItem > StreamDefinitions [get]
 Returns a collection that defines how each of the active streams are configured. The property collection contains the specific settings for the stream, like 'Codec', 'FPS', 'Resolution' and more for a camera stream.
StreamFolder StreamFolder [get]
ICollection< StreamUsageChildItem > StreamUsages [get]
 Returns a collection that defines how each of the active streams are used, e.g. for live and/or recording.
- Properties inherited from VideoOS.Platform.ConfigurationItems.IConfigurationItem
Guid Guid [get]
 Returns the id property or part of the path, when available. When no id is available this will be Guid.Empty. This is relevant for some items of ItemCategory.ChildItem where no property with key = "Id" exists and path does not contains a guid.
Collection< string > Methods [get]
 The available methods for this class.
- Properties inherited from VideoOS.Platform.ConfigurationItems.IConfigurationChildItem
string Description [get, set]
 Description.
virtual string DisplayName [get]
 Name of this ConfigurationItem in user readable format. Usually the same as property with key = "Name".
string ItemCategory [get]
 Return the item category for this item. This can be used to understand how multiple items are fetched and saved together. Only ItemCategory == 'Item' can be saved.
string Name [get, set]
 Name.
string ParentItemPath [get]
 Get hold of the next real parent path, e.g. skip any 'Folder' type parent.
string ParentPath [get]
 The path for the parent of this ConfigurationItem.
string Path [get]
 The identification of this item.
ServerId ServerId [get, set]
 Contains the ServerId of the Management Server holding this item.
Detailed Description
Constructor & Destructor Documentation
◆ Camera() [1/3]
VideoOS.Platform.ConfigurationItems.Camera.Camera ( ServerId serverId,
ConfigurationItem camera )
inline
Parameters
serverIdIdentify the Management Server that owns the configuration
cameraThe ConfigurationItem returned from elsewhere
Exceptions
ArgumentMIPExceptionWhen LoginSettings not found for serverId
◆ Camera() [2/3]
string path )
inline
This construction will contact the server and read the specified item.
Parameters
pathThe path of a specific item
Exceptions
MIPExceptionRepresents a number of possible exceptions. Possible exceptions can be found via the inherited exceptions - like PathNotFoundMIPException
◆ Camera() [3/3]
VideoOS.Platform.ConfigurationItems.Camera.Camera ( FQID fqid)
inline
Parameters
fqidIdentify the MIP item
Exceptions
Member Function Documentation
◆ ChangeDeviceRecordingStorage() [1/2]
ChangeDeviceRecordingStorageServerTask VideoOS.Platform.ConfigurationItems.Camera.ChangeDeviceRecordingStorage ( )
inline
◆ ChangeDeviceRecordingStorage() [2/2]
ServerTask VideoOS.Platform.ConfigurationItems.Camera.ChangeDeviceRecordingStorage ( String itemSelection,
bool moveData )
inline
Parameters
itemSelectionSelect a storage to move to
moveDataThis property is deprecated and will be ignored.
◆ ChangeSecurityPermissions() [1/2]
ChangeSecurityPermissionsServerTask VideoOS.Platform.ConfigurationItems.Camera.ChangeSecurityPermissions ( )
inline
Edit permissions.
◆ ChangeSecurityPermissions() [2/2]
ServerTask VideoOS.Platform.ConfigurationItems.Camera.ChangeSecurityPermissions ( String userPath)
inline
Edit permissions.
Parameters
userPathUser path. User path format: /User[SID]. 'SID' can contain role ID.
◆ GetOtherRecordingServersWithMedia()
ClassCollectionServerTask VideoOS.Platform.ConfigurationItems.Camera.GetOtherRecordingServersWithMedia ( )
inline
◆ GetOtherRecordingStoragesWithMedia()
ClassCollectionServerTask VideoOS.Platform.ConfigurationItems.Camera.GetOtherRecordingStoragesWithMedia ( )
inline
◆ GetPtzAbsolutePosition()
ServerTask VideoOS.Platform.ConfigurationItems.Camera.GetPtzAbsolutePosition ( )
inline
◆ JpegGetLive()
ServerTask VideoOS.Platform.ConfigurationItems.Camera.JpegGetLive ( int width,
int height )
inline
Parameters
widthThe maximum width of the image
heightThe maximun height of the image
◆ RetrieveEdgeStorage() [1/3]
RetrieveEdgeStorageServerTask VideoOS.Platform.ConfigurationItems.Camera.RetrieveEdgeStorage ( )
inline
◆ RetrieveEdgeStorage() [2/3]
ServerTask VideoOS.Platform.ConfigurationItems.Camera.RetrieveEdgeStorage ( DateTime startTime,
DateTime endTime )
inline
Parameters
startTimeStart time
endTimeEnd time
◆ RetrieveEdgeStorage() [3/3]
DateTime endTime,
String identifier,
Collection< string > relatedTasks )
inline
Parameters
startTimeStart time
endTimeEnd time
identifierJob identifier. Must be either empty or a valid GUID
relatedTasksRelated edge retrieval tasks. Identifiers of related edge retrieval tasks. Must be a list of valid GUIDs.
◆ SendDriverCommand()
ServerTask VideoOS.Platform.ConfigurationItems.Camera.SendDriverCommand ( string command,
string parameter,
int timeOut )
inline
Parameters
commandThe command to be send by the driver to the device, as a relative URI
parameterThe GET query string or POST data. Do not prepend the query string with ?
timeOutTimeout in milliseconds. If 0 this is a fire and forget and the call will just return right away without waiting for a response
◆ SetPtzAbsolutePosition()
ServerTask VideoOS.Platform.ConfigurationItems.Camera.SetPtzAbsolutePosition ( double pan,
double tilt,
double zoom,
double speed,
bool allowRepeats )
inline
Parameters
panPan value (between -1.0 and 1.0)
tiltTilt value (between -1.0 and 1.0)
zoomZoom value (between 0.0 and 1.0)
speedSpeed to use during movement (between 0.0 and 1.0)
allowRepeatsIf false repeated requests with identical values will be ignored
◆ TruncateStorage()
ServerTask VideoOS.Platform.ConfigurationItems.Camera.TruncateStorage ( )
inline
◆ TruncateStorageOnOtherRecordingServer() [1/2]
TruncateStorageOnOtherRecordingServerServerTask VideoOS.Platform.ConfigurationItems.Camera.TruncateStorageOnOtherRecordingServer ( )
inline
◆ TruncateStorageOnOtherRecordingServer() [2/2]
ServerTask VideoOS.Platform.ConfigurationItems.Camera.TruncateStorageOnOtherRecordingServer ( String itemSelection)
inline
Parameters
itemSelectionSelect recording server
Property Documentation
◆ Channel
int VideoOS.Platform.ConfigurationItems.Camera.Channel
get
Channel.
◆ ClientSettingsFolder
ClientSettingsFolder VideoOS.Platform.ConfigurationItems.Camera.ClientSettingsFolder
get
◆ CoverageDepth
double VideoOS.Platform.ConfigurationItems.Camera.CoverageDepth
getset
◆ CoverageDirection
double VideoOS.Platform.ConfigurationItems.Camera.CoverageDirection
getset
◆ CoverageFieldOfView
double VideoOS.Platform.ConfigurationItems.Camera.CoverageFieldOfView
getset
◆ CreatedDate
DateTime VideoOS.Platform.ConfigurationItems.Camera.CreatedDate
get
◆ CustomPropertiesFolder
CustomPropertiesFolder VideoOS.Platform.ConfigurationItems.Camera.CustomPropertiesFolder
get
◆ DeviceDriverSettingsFolder
DeviceDriverSettingsFolder VideoOS.Platform.ConfigurationItems.Camera.DeviceDriverSettingsFolder
get
◆ EdgeStorageEnabled
bool VideoOS.Platform.ConfigurationItems.Camera.EdgeStorageEnabled
getset
◆ EdgeStoragePlaybackEnabled
bool VideoOS.Platform.ConfigurationItems.Camera.EdgeStoragePlaybackEnabled
getset
◆ Enabled
bool VideoOS.Platform.ConfigurationItems.Camera.Enabled
getset
◆ FailoverSetting
String VideoOS.Platform.ConfigurationItems.Camera.FailoverSetting
getset
◆ FailoverSettingValues
Dictionary<string, string> VideoOS.Platform.ConfigurationItems.Camera.FailoverSettingValues
get
◆ FisheyeLensFolder
FisheyeLensFolder VideoOS.Platform.ConfigurationItems.Camera.FisheyeLensFolder
get
◆ GisPoint
string VideoOS.Platform.ConfigurationItems.Camera.GisPoint
getset
◆ HardwareDeviceEventFolder
HardwareDeviceEventFolder VideoOS.Platform.ConfigurationItems.Camera.HardwareDeviceEventFolder
get
◆ Icon
int VideoOS.Platform.ConfigurationItems.Camera.Icon
getset
◆ Id
string VideoOS.Platform.ConfigurationItems.Camera.Id
get
ID.
◆ LastModified
DateTime VideoOS.Platform.ConfigurationItems.Camera.LastModified
get
Last modified.
◆ ManualRecordingTimeoutEnabled
bool VideoOS.Platform.ConfigurationItems.Camera.ManualRecordingTimeoutEnabled
getset
◆ ManualRecordingTimeoutMinutes
int VideoOS.Platform.ConfigurationItems.Camera.ManualRecordingTimeoutMinutes
getset
◆ MotionDetectionFolder
MotionDetectionFolder VideoOS.Platform.ConfigurationItems.Camera.MotionDetectionFolder
get
◆ PatrollingProfileFolder
PatrollingProfileFolder VideoOS.Platform.ConfigurationItems.Camera.PatrollingProfileFolder
get
◆ PrebufferEnabled
bool VideoOS.Platform.ConfigurationItems.Camera.PrebufferEnabled
getset
Prebuffer enabled.
◆ PrebufferInMemory
bool VideoOS.Platform.ConfigurationItems.Camera.PrebufferInMemory
getset
◆ PrebufferSeconds
int VideoOS.Platform.ConfigurationItems.Camera.PrebufferSeconds
getset
Prebuffer seconds.
◆ PrivacyProtectionFolder
PrivacyProtectionFolder VideoOS.Platform.ConfigurationItems.Camera.PrivacyProtectionFolder
get
◆ PtzEnabled
bool VideoOS.Platform.ConfigurationItems.Camera.PtzEnabled
get
PTZ enabled.
◆ PtzPresetFolder
PtzPresetFolder VideoOS.Platform.ConfigurationItems.Camera.PtzPresetFolder
get
◆ RecordingEnabled
bool VideoOS.Platform.ConfigurationItems.Camera.RecordingEnabled
getset
Recording enabled.
◆ RecordingFramerate
double VideoOS.Platform.ConfigurationItems.Camera.RecordingFramerate
getset
◆ RecordingStorage
String VideoOS.Platform.ConfigurationItems.Camera.RecordingStorage
get
◆ RecordKeyframesOnly
bool VideoOS.Platform.ConfigurationItems.Camera.RecordKeyframesOnly
getset
◆ RecordOnRelatedDevices
bool VideoOS.Platform.ConfigurationItems.Camera.RecordOnRelatedDevices
getset
◆ ShortName
string VideoOS.Platform.ConfigurationItems.Camera.ShortName
getset
◆ StreamDefinitions
ICollection<StreamChildItem> VideoOS.Platform.ConfigurationItems.Camera.StreamDefinitions
get
Please note that this should only be used for reading the settings. If you need to update them, you should go through the DeviceDriverSettingsFolder.
Replaces code like:
var streamDefinitions = camera.DeviceDriverSettingsFolder.DeviceDriverSettings.First().StreamChildItems; With
var streamDefinitions = myCamera.StreamDefinitions
◆ StreamFolder
StreamFolder VideoOS.Platform.ConfigurationItems.Camera.StreamFolder
get
◆ StreamUsages
ICollection<StreamUsageChildItem> VideoOS.Platform.ConfigurationItems.Camera.StreamUsages
get
Replaces code like:
var streamUsages = myCamera.StreamFolder.Streams?.FirstOrDefault()?.StreamUsageChildItems;
With
var streamUsages = myCamera.StreamUsages
