Alternative user interface application
To have a company-specific look-and-feel for the operators, an end user application can be developed utilizing a set of Milestone protocols.
Description
This would be an alternative to the Milestone Smart Client. This application can choose to use some of the MIP components that encapsulate the protocols or access the protocols directly.
Alternative User Interface Application
1) Milestone server
2) Operator application
The relevant protocols are the Image Server protocol, Server Command protocol and Recorder Command protocol.
The Status protocol should be included if status and monitoring is also required.
Sample
