Analytics integration with XProtect Event Server
Analytics integration with any camera attached to a Milestone server.
Description
Analytics based on video coming from the Milestone image server interface. Could be integrated by Milestone Toolkit or connecting directly to the image server API. Outcome of the analytics are send to XProtect event server for storage and alarm management.
1) Milestone server
- No plug-in development is required on the server.
- Address information stored on 1) for how to connect to 3).
2) Administrator
- Plug-in development required for selecting the cameras and passing on to server 3).
3) Partner developed server
- Retrieving video from the Milestone image server via Milestone Toolkit or direct TCP/IP connection to the Milestone image server. Analytics results are sent to the XProtect event server via MIP SDK on 3) or directly using TCP/IP.
4) Milestone XProtect event server
- Milestone XProtect event server stores Analytics Events. No plug-in development required here. Alarm rule and management as for all other events.
5) Smart Client
- No plug-in development required here, as the standard plug-in for alarm management is used to display analytics alarms.
