Event and State WebSocket API - Python
This sample demonstrates how to access the Events and State WebSocket API through the API Gateway from a Python application.
Prerequisites
XProtect 2023 R3 or later with API Gateway installed
Items configured, that can trigger events (e.g. cameras or user-defined events)
Credentials for a user in the VMS (basic or Windows user)
Python 3.11 (https://www.python.org/)
Packages listed in
requirements.txt:pip install -r requirements.txt
Run
python main.py
The sample demonstrates
- How to create a WebSocket connection and authenticate on the Events and State API
- How to create a session and resume the session in case of a connection failure (recovering missed events)
- How to make a subscription based on a source, a source type and/or an event type
- How to keep track of the state of configuration items based on stateful events
- How to get the current state based on an active subscription
- How to use the Configuration RESTful API to look up ids in the event: source, event type, and event group.
Subscription options
The basic subscription filter is defined in the top of
main.py and can be modified for different sources, a source
types and/or an event types. A few ids for some common events types can
be found in event_type.py.
To define a more advanced subscription with multiple filters
(potentially including ‘exclude’ filters), see the
create_subscription() method in
ess_api.py.
Simplified example
gateway_ws_uri = "wss://localhost/api/ws/events/v1/"
access_token = "<insert token>"
session_id = ""
last_event_id = ""
subscription_filters = [
"modifier": "include",
"resourceTypes": [ "outputs" ],
"sourceIds": [ "*" ],
"eventTypes": [ "*" ]
while True:
try:
async with connect(gateway_ws_uri, extra_headers={"Authorization": f"Bearer {access_token}"}) as web_socket:
# Start or resume session
session = await ess_api.start_session(web_socket, session_id, last_event_id)
if session["status"] == 201:
# Create subscription
subscription = await ess_api.create_subscription(web_socket, subscription_filters)
# Save session id once subscription is successfully created
session_id = session["sessionId"]
# Get state (if needed)
state = await ess_api.get_state(web_socket)
# TODO: Process state
# Receive events loop
while True:
events = await ess_api.receive_events(web_socket)
last_event_id = events["events"][-1]["id"]
# TODO: Process events
except:
# TODO: Exception handling
# Sleep 1 second before reconnecting
await asyncio.sleep(1)
print("Reconnecting...")Using
- Event and State WebSocket API
- Configuration RESTful API
- OpenID Connect/OAuth2
