Introduction
Introduction to MIP SDK 2018 R1
Discontinuation
2018 releases will be the last MIP SDK releases to include the following components: ImageViewer, AudioPlayer, EngineManager ActiveXs and the "UseActiveX" environment option.
Existing applications using these components should not be affected during 2018 since maintenance work on these components will continue until 2019 R1, but with no new functionality added.
With MIP SDK 2019 R1 these components will be officially discontinued and will no longer be included in the MIP SDK. For Web and C++ development, we strongly recommend developers to already now start using the Mobile Server interface instead. As for Windows based applications, we recommend using the ImageViewerControl or ImageViewerWpfControl .NET controls.
MIPSDK General
Configuration API
In addition to the privacy protection mask support mentioned above the following has been added to the Configuration API:
In addition to the support in the strongly typed classes the above support has of course also been added to the raw configuration API.
Samples
Fixed issues
