Events and State subscription
Introduction
Events and state subscriptions are based on a WebSocket API where applications can subscribe to specific events and state.
What it is used for
An events and state session allows an application to receive events from an XProtect system on a persistent connection. The application can granularly specify which events are of interest and use stateful events to keep track state.
The same session can also be used to retrieve state on-demand.
If the connection is interrupted, events will be cached on the server and can be retrieved if the client reconnects within a timeout (default: 30 seconds).
Classes
Class | Description |
VideoOS.Platform.EventsAndState.EventsAndStateSession | Static class containing a
Create method for creating an
IEventsAndStateSession with a specified
IEventReceiver . |
VideoOS.Platform.EventsAndState.IEventsAndStateSession | Interface used for subscribing to events and getting state. |
VideoOS.Platform.EventsAndState.IEventReceiver | Interface implemented by user code for receiving events and connection state. |
VideoOS.Platform.EventsAndState.SubscriptionRule | Subscription rules specifying which events should be received. |
Functionality
Event receiver
Implement the IEventReceiver
interface to be able to
receive events and state.
This interfaces will deliver events on the
OnEventsReceivedAsync
method.
The interface also delivers the state of the underlying connection to
the XProtect system on the OnConnectionStateChangedAsync
method.
Creating a session with an even receiver
The static class EventsAndStateSession
has a factory
method to create a session for receiving events and state. Calling the
create method and passing the login settings (see Component environments for login) and an event
receiver, will create a session defined by the interface
The IEventsAndStateSession
interface is where an
application can add/remove subscriptions and get the current state.
Defining subscription rules for a session
Subscription rules specify which events should be received in a session.
When defining a SubscriptionRule
, it is possible to
specify either specific types/ids that should be matched or indicate
that all types/ids should be matched.
Available event types, states and event source(s) can be looked up using the RESTful Configuration API
Subscription rules can be added to an
using the
AddSubscriptionAsync
method, which returns a subscription
id. The subscription id can be used to remove the subscription
again.
Subscription properties
Property | Description |
Modifier |
Determines if the specified events are
excluded or included. Available values are Include and
Exclude . |
ResourceTypes |
Specifies which resource type(s) that are
covered by this rule. E.g., “recordingServers”, “hardware”, “cameras”.
It is also possible to use one of the GUIDs defined in the static class
Kind . |
SourceIds |
Specifies specific source(s) that are covered by this rule. |
EventTypes |
Specifies specific event type(s) that are
covered by this rule. All event types currently defined in an XProtect
system can be retrieved using the RESTful Configuration API using the
resource path /eventTypes . Alternatively, pre-defined event
types can be found in the static class KnownStatusEvents . |
NOTE:
An event must match all specifiers to be covered by a rule.
Relation between a session, subscription rules and modifiers
- A session must be established before any subscriptions can be created.
- A subscription may contain multiple subscription rules.
Include
andExclude
controls whether the events specified in the subscription rule are included or excluded.Exclude
modifiers have higher priority thaninclude
modifiers - i.e., if an event is excluded by any subscription rule, it cannot be included by another subscription rule in the same subscription.- A client can create multiple subscriptions.
- Individual subscriptions do not affect each other - i.e., events matching any subscription will be received, and events included in one subscription cannot be excluded by another subscription.
- An event that is included in multiple subscriptions will only be sent to the client once.
Remove a subscription
Remove a previously created subscription specified by the subscription id.
Getting events
Events are received in the OnEventsReceivedAsync
method
of the IEventReceiver
implementation.
Getting state
An application can get the current state satisfying the subscription
by calling GetCurrentStateAsync
. Alternatively, the
application can request all stateful events by calling
SendAllStatefulEventsAsync
. Stateful events will then be
method of the
IEventReceiver
implementation.
This can be useful to retrieve the initial state after one or more subscriptions have been made.
Connection state
Changes in the state of the underlying connection are received in the
method of the
IEventReceiver
implementation. See VideoOS.Platform.EventsAndState.ConnectionState
for the possible connection states and their meanings.
If disconnected, the connection will automatically be reestablished and the session resumed.
If the session is successfully resumed, then all missed events will
be retrieved. If the session cannot be resumed (e.g. if the 30 second
timeout has expired), a new session will be created with the previously
defined subscriptions. If SendStatefulEventsOnReconnect
is
set on the IEventsAndStateSession
(default is
true
), then the current state will automatically be be
received as stateful events in OnEventsReceivedAsync
Sample code
SampleAsync()
async Task {
var loginSettings = LoginSettingsCache.GetLoginSettings(EnvironmentManager.Instance.MasterSite);
// Create event receiver and session
var eventReceiver = new EventReceiver();
var session = EventsAndStateSession.Create(loginSettings, eventReceiver);
// Add subscription
var subscription = new[]
new SubscriptionRule(
.Include,
Modifiernew ResourceTypes(new[]{ "cameras" }),
.Any,
SourceIdsnew EventTypes(new[]{ KnownStatusEvents.CommunicationStarted, KnownStatusEvents.CommunicationStopped }))
.AddSubscriptionAsync(subscription, default);
await session
// Send initial state as events, if needed
.SendAllStatefulEventsAsync(default);
await _session
// Run application / Wait for shutdown
// Call _session.Dispose() to stop receiving events and close the underlying connection
class EventReceiver : IEventReceiver
public async Task OnConnectionStateChangedAsync(ConnectionState newState)
// Handle connection state change
public async Task OnEventsReceivedAsync(IEnumerable<Event> events)
// Handle events
Sample
- Event and state viewer Sample
See also
- API Gateway - RESTful APIs General documentation about the API Gateway.
- MIP VMS API Getting started How to obtain and use an OAuth bearer token.
