Component environments for login
The MIP SDK (component) environments and how to log in to them.
MIP SDK provides three environments for authentication and initialization in component (stand-alone) solutions: one general environment for most use cases, and two designed to handle special use cases. The three environments are:
| Environment class | Description |
| VideoOS.Platform.SDK.Environment |
This environment handles the general case of one user connected directly to one XProtect VMS site. Code samples: almost all component samples. |
| VideoOS.Platform.SDK.MultiEnvironment |
MultiEnvironment is designed to have one or more users connect to two or more
XProtect VMS sites. This makes it possible to combine data from several sites
without them being set up in a MFA. Login settings and session data for each user is
maintained in a Milestone Interconnect uses MultiEnvironment. Code sample: System Status Client Console. |
| VideoOS.Platform.SDK.MultiUserEnvironment |
MultiUserEnvironment is used to manage multiple users connected to one XProtect VMS
site. The MultiUserEnvironment one overall user to monitor the XProtect VMS and
update the XProtect Mobile server uses MultiUserEnvironment. Code sample: Multi-User environment. |
Log in to the environments
Credential types
All three MIP SDK environments support the following credential types:
- XProtect basic user - created locally with username and password in an XProtect VMS. An XProtect basic user won't be able to access MFA child sites.
- Windows user - created in the AD (Active Directory) of the XProtect VMS and given access to the XProtect VMS.
- OAuth token - authenticating using an identity token provided by an IDP (internal or external Identity Provider).
secureOnly and masterOnly
In all three MIP SDK environments, methods that update the environment in preparation
of login have the parameters secureOnly and masterOnly.
| Parameter | Description |
If |
An XProtect VMS site that is part of a Milestone Federated Architecture (MFA)
hierarchy can have one or more child sites. MFA requires Corporate license for
parent (center) sites and Corporate or Expert licenses for child (remote) sites.
Default is |
Credentials
The MIP SDK provides helper methods for creating and handling
System.Net-based login credentials, and the class
MipTokenCache for handling OAuth-based authentication.
| Credentials | Method | Description |
Provides credentials for password-based authentication schemes (Basic, Windows, or Windows default user). |
Provides storage for multiple credentials. |
A |
In some cases, users might want to use a ManualMipTokenCache, which is
instantiated with the JWT token received from the IDP server. The
ManualMipTokenCache will not update the token, but the object can be parsed
to any methods that require a MIPTokenCache and the token can be updated
using the method UpdateAccessToken.
The code snippets below uses different kind of credential mechanisms to demonstrate how credentials are created and used.
See also the section Login Process in .NET Library Initialization.
Log in to Environment
VideoOS.Platform.SDK.Environment.Initialize();
Uri mangementServerUri = new Uri("https://mangementserverUrl");
bool secureOnly = true;
bool masterOnly = true;
Guid integrationId = new Guid("7A7B4B62-A6F1-49E4-9C61-D541CC54411A");
string integrationName = "TestIntegration";
string version = "1.0.0.0";
string manufacturerName = "TestCompany";
CredentialCache cc = VideoOS.Platform.Login.Util.BuildCredentialCache(mangementServerUri, "basicUser", "Password", "Basic");
VideoOS.Platform.SDK.Environment.AddServer(secureOnly, mangementServerUri, cc, masterOnly);
try
VideoOS.Platform.SDK.Environment.Login(mangementServerUri, integrationId, integrationName, version, manufacturerName, masterOnly);
catch (. . .)
Uri managementServerUri = new Uri("https://mangementserverUrl");
Uri idpServerUri = new Uri("https://mangementserverUrl/IDP");
bool isBasicUser = false;
bool masterOnly = false;
NetworkCredential networkCredential = VideoOS.Platform.Login.Util.BuildNetworkCredential(managementServerUri, @"AD\AdUser", "Password", "Negotiate");
MipTokenCache mipTokenCache = new MipTokenCache(idpServerUri, networkCredential, isBasicUser);
VideoOS.Platform.SDK.Environment.AddServerOAuth(secureOnly, managementServerUri, mipTokenCache, masterOnly);
try
catch(. . .)
Log in to MultiEnvironment
bool usingAD = true;
MultiEnvironment.InitializeUsingUserContext();
var userContext = MultiEnvironment.CreateSingleServerUserContext(secureOnly, @"domain\username", "password", usingAD, mangementServerUri);
bool loginSucceeded = MultiEnvironment.LoginUserContext(userContext);
Log in to MultiUserEnvironment
Uri managementServerUri = new Uri("https://managementserverUrl");
// This user must have a role with overall access, for example Administrators
VideoOS.Platform.SDK.MultiUserEnvironment.InitializeUsingUserContext(secureOnly: true, uri, "BasicUser", "Password", usingAD: false, masterOnly: false);
if (VideoOS.Platform.SDK.MultiUserEnvironment.InitializeLoggedIn == false)
// Do some cleanup
VideoOS.Platform.SDK.MultiUserEnvironment.UnInitialize();
return;
// Create a MultiUserEnvironment and log in an ordinary user
UserContext userContext1 = VideoOS.Platform.SDK.MultiUserEnvironment.CreateUserContext(@"Domain\ADUser", "ADPassword", usingAD: true);
try
VideoOS.Platform.SDK.MultiUserEnvironment.LoginUserContext(userContext1);
catch(Exception ex)
throw new Exception("Login failed", ex);
Log in using protocols
Stand-alone integrations doesn't have to use the MIP SDK component .NET libraries; it is possible to log in and access an XProtect VMS using network protocols. XProtect supports several generations of protocols: SOAP and the MIP VMS API.
SOAP
- SOAP services for XProtect General documentation about XProtect SOAP protocols.
- Authentication and authorization Log in using
ServerCommandServiceto use SOAP services or the ImageServer protocol.
MIP VMS API
- API Gateway - RESTful APIs General documentation about the API Gateway.
- MIP VMS API Getting started How to obtain and use an OAuth bearer token
