Audio integrations
Audio integrations can be related to microphones or loudspeakers that are attached to a camera.
For microphones that are attached to a camera, you can play the sound from the microphone alone or together with video. You can also export microphone audio.
For loudspeakers that are attached to a camera, you can transmit sound from an application or service, and play it on the loudspeaker. Both live audio from the local microphone on a PC and WAV files can be transmitted to a loudspeaker.
Following is an overview of the two types of audio devices to integrate.
You can connect loudspeakers and microphones to a Milestone XProtect video management software.
Loudspeakers and microphones can be stand-alone devices but can also be an integrated part of a camera.
Loudspeaker Integrations
Flow of audio for camera attached loudspeakers.
Microphone Integrations
Flow of audio for camera attached microphones.
The illustrations above show a number of different ways to connect microphones and loudspeakers attached to cameras to a Milestone XProtect video management software.
