3rd Party Driver Test Tool guide
Introduction
Drivers developed using the MIP SDK Driver Framework, also known as 3rd-party drivers, must be verified by Milestone before they can be listed on the Milestone Marketplace.
The 3rd Party Driver Test Tool simplifies development and verification of MIP Driver Framework-based drivers:
This tool is not a replacement for testing with Milestone XProtect® VMS. Rather, it provides an overview of the implemented functionalities, and attempts to detect inconsistencies and erroneous behaviour by analyzing the driver and running tests with connected devices.
The tool is part of the Milestone SDKTools which is available from the Download software.
Overview
The 3rd Party Driver Test Tool user interface consists of these sections and controls:
Section/control Description
Driver definition path Enter the path to the driver .def file or click Browse to select a driver .def file.
Examine Click Examine to load and analyze the selected driver.
Driver Info Displays ID, Name, Group Name and Version as defined in the loaded driver.
Supported Products Displays the list of supported hardware products as defined in the loaded driver.
Dynamic Tests Fill in connection info and credentials for a device that is online and reachable.
Run Click Run to execute tests. Results appear in the Driver Overview and Logs sections.
Driver Overview Displays all device definitions found in the loaded driver. Each device is listed in a tree structure containing its settings, events, and capabilities.
The Common Hardware node is generated by the tool and displays all settings and events that are defined at the hardware level.
+ and - Use + (Expand All) or - (Collapse All) for fast control of the whole tree view.
Logs Displays logs generated during loading the driver and running the dynamic tests.
Export Click Export to save the information available at export time in a report file.
Import Click Import to import and visualize an existing report file.
Testing a driver
The driver test workflow consists of these steps:
  1. Start the 3rd Party Driver Test Tool
  2. Select a driver, and load and analyze the driver device definitions.
  3. Run dynamic tests of driver functionalities with a connected device.
  4. Export the gathered information and logs into a report file.
Starting the 3rd Party Driver Test Tool
By default, the tool is located in the folder C:\Program Files\Milestone\MIPSDK\Tools\3rdPartyDriverTestTool.
To start the tool, double-click 3rdPartyDriverTestTool.exe or run C:\Program Files\Milestone\MIPSDK\Tools\3rdPartyDriverTestTool\3rdPartyDriverTestTool.exe.
Loading and static analysis of the driver
The tool does not load the driver .dll directly. Instead it uses the .def XML file that specifies the name of the driver .dll to locate it, in the same way the XProtect VMS does.
After selecting the driver .def file, click Examine to initiate driver loading and analysis.
The tool performs several sanity checks on both the .def file and the .dll file. The driver load and analysis may fail due to different reasons, such as:
After the driver has been loaded successfully, the tool fills in the Driver Info and Supported Products sections, as well as the Driver Overview section and the Logs section.
Any inconsistencies found during the analysis phase are logged as either Warnings or Errors, depending on their severity.
Each Driver Device tree in the Driver Overview section is a direct representation of a single DeviceDefinition instance in the driver. The structure depends on the device type and defined capabilities.
Here is a formal description of the structure of each Driver Device tree as seen in the tool:
DeviceType : "Device Name"
<Stream Definition>:
<Metadata Support Definition>:
<Setting Definition>:
<PTZ>:
<Output>:
The tree view only shows the events from the device definitions in the driver. If the driver uses built-in events provided by MIP SDK Driver Framework without explicitly defining them, they do not appear in the tree. Such events are InputActivated, InputDeactivated, OutputActivated, OutputDeactivated, etc.
Dynamic tests
To run dynamic tests with the loaded driver, the tool needs to connect to a supported hardware product.
Each functionality in the driver, e.g. Streaming or PTZ, is implemented in the driver via a separate Manager class that provides API methods for working with that functionality. The goal of the dynamic tests is to check whether functionalities are implemented in the driver, and whether they work as expected.
The tool executes different sets of tests for each device type. Each test verifies a single API method of the corresponding Manager class.
For better visibility of unintentional omission, the tool lists all tests that are relevant to a Manager class dealing with a device/capability.
Running the tests
To start the tests, fill in valid connection info (IP/Hostname, Port) and credentials (User Name, Password) for the connected device in the Dynamic Tests section and click Run.
Test info and results
The tool displays the test info lines directly below the tested device/capability in the Driver Overview section.
Each test info line has the following format: TestType (Result): TestName AdditionalInfo
There are four types of test results:
If the initial connection to the device fails, the tool does not attempt to execute the tests. Instead, it logs an Error with the reason for the failed connection. The Error log is based on the information returned by the driver, e.g. authentication error.
The Dynamic tests do not cover Event and Input polling functionalities.
Exporting generated reports
After each major step - loading the driver, executing the dynamic tests - you can click Export to generate and export a test report.
The report is saved as a .json file that contains the full information available at export time:
In addition, the report contains the version of the tool with which it is created.
Reports are an easy way to keep snapshots of the state of the driver during development, and for reference at a later point in time.
They are also used in Milestone's driver verification process.
Reviewing existing reports
Click Import to select and open a .json report file.
On successful import, the tool visualizes the report data identically to a just loaded driver, with or without dynamic test execution information, along with all saved logs.
The imported report is read-only and cannot be modified or exported.
If the report was created with a newer or older version of the 3rd Party Driver Test Tool, a warning message appears on Import. You may choose whether to continue loading the report or cancel.
In case of a corrupted report file, the tool stops loading the report and issues an error:
